My cassette does not go in it always pops out
SOURCE: software for the canon zr300 mini dv digital camcorder
You will likely have to order this through Canon.
SOURCE: Canon Elura 60-wont load mini dv
mine just won't load the tape. mechanism closes fine when I take the tape away and try door. sits there until I do.
SOURCE: DV cassette does not come out
Please please please DO NOT spray anything in to the camera. The problem is that the main drive belt is slipping or the motor is tired and the mechanism is not completing the unload cycle. This is a trivial repair for an experienced camera tech. The belt should not be more than a couple of $$. The rubber has dried up a bit and is now a little slippery. Call around for the best labor rate and have the unit repaired. It is worth it.
Dan
SOURCE: During playback, only seee a blue screen.
kindly rate me if ui have helped u !
i hope ur problem gets solved
