Question about Powr Flite PAS20DX Canister Vacuum
Why does battery die so fast
With brand new batteries auto scruber last about three days. four months later will barley scrub one whole basketball court. just wondering if there is a better way or proper way to charge it.
Posted by nickyballs21 on
Anonymous
    New Friend:
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 66 Answers
Use till battery is dead, then put a full charge one it, if it has water ports, check to see if at proper level, if still bad, take to have tested, look in phone book(batteries) if it test ok, charger is bad
Posted on May 19, 2010
My hoover spin scrub has no suction wont pick up water why?
No suction means somewhere in the intake side of the system you have either a blockage or an air leak.
Jan 21, 2015 | Hoover Brand New SteamVac Spin Scrub...
DC25 three broken heads
yes the wires are probable not properly connected to the brush bar motor dyson is not like other vacuums if you reverse the wires the motor does not turn it reverse it simply stop rewire it correctly or take it to guarantee vacuum and sewing center for better comsumption they have a lifetime warenty on them that should cover that all dyson vacuums do
Mar 21, 2014 | Dyson DC25 All Floors Bagless Upright...
Neato seems to have died but the green light is on
Mine was doing same thing. was working flipped upside down to replace the rubber blades then nothing.Display dark only it has green led around orange button. Unplugging batteries didn't help.pressing buttons nothing. holding buttons down nothing. Found this on another site. Connect the vac to your computer and place it on charger at same time. Press and hold the orange button for about 10 sec. or so. it should turn of the LED then let up and repress button. vac should then reboot. Unplug computer. Wouldn't hurt at this time to tell it you put in "New Batteries" but first remove any scheduled cleaning days to clear its memory. After doing the New battery, reset the schedule and let it charge. After that it maybe a good time to check your program version and update it from the Neato web site to the newest update. The newest update does wonders for the battery run time issues.
Feb 07, 2014 | Neato XV11 Vacuum
How can i tell the year my kirby diamond ultimate g was built?
Look at the serial #. Disregard the first number. The next two represent the year, the next two the month, and the next two the day. The last three are the daily sequence.
Example: 5021203456, would be the 456th machine finished on Dec. 3, 2002.
Jul 26, 2011 | Kirby Ultimate G Bagged Upright Vacuum
When to recharge batter
hi right to be honest both ways are correct, but if your using it every day then its best to put it back on the charger after every use, but the problem with this is that the battery never goes totally flat, so never does a full recharge this reduces the life of the battery by upto 50% so if you are using it regular and need it charged daily then its best to once a month let the battery go totally flat so that it wont even make a sound then do a full recharge.
Doing this will ensure the battery remains at peak performance and make it last longer.
If how ever your only using it say once a week then its best to only charge after the battery has gone flat due to the fact that it would remain on charge longer and cause the battery to over heat reducing the life span of the battery.
But witch ever method you use always let the battery go totally flat once a month then do full recharge this will prolong the life of the battery and ensure it keeps working at full power.
Let me know if you have further questions ok
Jan 18, 2010 | Euro-Pro Shark Cordless Stick Vacuum...
Bissell Lift OfF Brush Roller Stops Rotating
They make the worst machines, the rollers are cheap and they make it so you cant take them apart to clean them. You don't want a dyson either, they aren't any better for pets. With all that hardwood floors you should get a good canister vacuum, sebo and miele are the best.
Aug 24, 2009 | Bissell Lift-Off(R) Revolution(R) Turbo...
Hoover all terrain dual v spin and scrub 12 amps
All of the hoover cleaners use air to spin the brushes the air intake is probably clogged. There is a Little clear window on the top of the machine pull that off and underneath is a little screen clean that out and that should fix your problem. If you need any parts or cleaner for your machine visit www.stevessewandvac.com
Aug 12, 2008 | Vacuums
Cannot find replacement piece for the scrub brushes.
The part number for this brush block is 48437022, most repair shops will have or can get it for you.
Jan 22, 2008 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
Powr Flite PAS20DX Canister Vacuum Logo
Top Powr Flite Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Powr Flite Vacuum Expert? Answer questions, earn points and help others
