THE DRUM BEARING HAS GONE THE SPOTTING IS FROM THE OIL IN THE BEARING .IF YOU TURN THE DRUM WITH YOUR HAND IT WILL FEEL LIKE IT IS RUNNING OVER A COBBLED STREET
BUY A NEW WASHER
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
SOURCE: loud noise in spin mode and black spots
This is joyce
How old is this unit?
this can be costly to fix, it may not be worth the cost, may just replace, the barrons in drum sounds like they are shot and the oil is from the inside gasket, my friend at work had the manufacture to replace her dryer because of this. you may want to call them if your unit is not to old, they also may have recall on your unit so call and make sure of this before you discard unit. go to webb site I have never heard of your unit so I am not familar with who makes this unit.
thanks
please grade me at end of session
joyce
