Question about Seagate Free Agent Go Small 12 GB USB External HD ST600121GSA1E1-RK USB 2.0 Hard Drive
New computer with windows 7 - when external Seagate pnk2al-510 is plugged in at start, windows will not boot up. boots up find when unplugged and works find if HD is plugged in after windows start.
Posted by Robert Kralowetz on
pcgeektech
    New Friend:
  • 58 Answers
First check the bios setting and see which device is your default booting.
Posted on May 18, 2010
Windows will not start with a Toshiba external hard drive plugged into USB
Computer starts normally in windows with a windows that is installed on a hard disk on that copmuter. In other words - windows is installed on an internal hard disk of a computer A. If you get it out and put in a computer B it wont work.
To have the things work:
1. First should set in BIOS boot up options first boot device CD/DVD, second OTHER/USB/EXTERNAL, third HDD
2. Should boot up from a CD and install windows on an external hard disk (in your case your 3TB Toshiba external HD)
3. Set in BIOS boot up options first boot device OTHER/USB/EXTERNAL, second internal hard disk e.g. HDD0, HDD1
Apr 04, 2014 | Toshiba Canvio Computers & Internet
I just upgraded my Windows Vista 64-bit computer to Windows 7 64-bit. Backed up all my documents onto a ST3200823A-RK Seagate external hard drive. I have used this HD for 3 years, and it has always...
if you external hdd does not work on any other computer other than yours . try opening it with a linux OS. u can Ubuntu live cd .. boot from it and run it live...connect your HDD .. i hope you can see you files then >>> good luck
Jun 20, 2011 | Seagate 160GB 3.5" External USB Drive 160...
I cannot boot my PC when the seagate hard drive is attached. I have to disconnect the external Seagate drive and then boot. Once booted I can physically plug in my seagate External Hard drive and it...
restart the system, while restarting , press delete/F8 to enter in BIOS menu, select boot priority and select the primary HDD as first boot device, deselct the "boot otehr device" option.
it should work fine.,
Cheers!
Sep 11, 2010 | Seagate Computers & Internet
500 GB Seagate freeagent classic - windows 7 won't start when power cord is connected. Okay to connect after boot up and HD works find. Is there a workaround that will allow the external HD to remain in...
Most likely the problem is that your computer is trying to boot from your external hard drive and that why windows 7 wont start up but it is a very easy fix. with the freeagent attached start up your computer system and when the first BIOS screen is displayed press either the F8 key or the ESC key to enter BIOS setup it should say on the screen which button you need to press. Once you press the correct button the BIOS set up screen will load there should be tabs at the top and select the boot tab, under the boot tab there will be a list of devices in the order that the computer will try and boot off of them all u need to do is move your freeagent to the bottom of the list and every thing will work perfect.
I hope this helped.
Thank you,
Norse
May 18, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Windows 7 on slave drive, can I format master now?
in your bios can you tell it what drive to boot from first. sorry for the lame question but im thinking its going to the defualt drive each time.
Nov 30, 2009 | Microsoft Windows XP Professional
After software install of the new HD my computer will not boot if the HD USb cable is left attached. If I unplug the USB cable then the computer will boot up.
please check the boot priority in cmos setting...if its 1 priority given from usb drive than it will not boot till u unplug it.
Apr 15, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Black screen
Some USB devices seem to cause this problem. I've had it myself. USB devices when hooked up cause the computer to freeze as it hard for USB drivers to be loaded outside of windows. Try updating you windows thru windows update though even updated I still run into the problem sometimes. If updating dosen't work you need to keep the drive unhooked while booting then hook up in windows.
Dec 11, 2007 | Dell Dimension 8400 PC Desktop
Seagate Free Agent Go Small 12 GB USB External HD ST600121GSA1E1-RK USB 2.0 Hard Drive Logo
147 people viewed this question
Top Seagate Computers & Internet Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
