= The Belkin Router Utility Might Not have Been Installed Properly.
> To Get Rid of this Issue 1st of all Disable or Uninstall Belkin Router Utility.
- Goto Start > Control Panel > Uninstall Programs
- Select Belkin Router Manager Utility & Uninstall It.
> Now you Have to Remove preferred Networks & Join the wireless Network.
Steps to Remove Preferred Network & Joining the Network
- Windows XP- Goto Start > Control Panel > Network Connections > Right Click on
Wireless Network Connection > Click on
Properties > Select
Wireless Networks Tab > Under
Preferred Networks Box > Select your Wireless Network Name & Click on
Remove Button. Close the window
- Right Click on Wireless Network Connection & Click on View Available wireless Networks.
- Wireless Network Connection window will appear. Select the network you wish to connect and click
Connect. It will ask you For a
Network Key Type in your Password.
Windows Vista & Windows 7- Go to Control Panel > Network and Sharing Center > Click on Manage wireless networks Right click on your
wireless Network > Click on
Remove Network . > Connecting to a
Wireless Network.
- Goto Network & Sharing Center Click
Connect to - Select your wireless network & click
Connect - It will ask you For a
Security Key Type in your Password.
( If you are unable to go online you can try power cycling the router for about 15 seconds. If Even Power cycling doesn't work that means you have to disable WPS option on the Belkin router)
