Question about Sunbeam 5891 Bread Maker
My breadmaker isn't working, the display works, but nothing happens when I enter in a program
Posted by annasw8 on
Dick Snider
    President:
  • 742 Answers
Check the troubleshooting section in your manual. You will get any Sunbeam breadmaker manual with the manualfox search engine. Check results here:
http://manualfox.com/link/sunbeam.htm
Posted on Jun 12, 2010
Model# 5844 digital display works, heat element works, will not start motor when switch is pushed
Is the lid closed? Many bread makers have a safety switch to keep the motor off if the lid is open. The blades are quite strong and could break your fingers.
Nov 25, 2015 | Kitchen Appliances - Others
Breadmaker will not startup
which program are you selecting? Is it whole wheat?
Jan 23, 2013 | West Bend WestBend Hi-Rise Breadmaker
Have just got a morphyrichards 48323 when it was turned on for the first time it went into program 1 and i was unable to select program 13 as sugested in instructions can i abort this or do i need to let...
Press and hold-in the start button (bottom one) for 10 seconds. This will abort the program that's been started and reset the machine. This isn't mentioned in the manual.
Jul 09, 2011 | Kitchen Appliances - Others
I just made a loaf of sweet bread and wanted to make a second loaf. Washed the bucket, loaded up the ingredients, plugged it in, and all I get is 0:00 on the display. Nothing else works.
plug your machine in and push "select" then push the button for the program you want 1, 3, 5 etc. etc. then push "start" email me if this doesn't work and we'll try something else or chat online etc.
Jan 04, 2011 | Breadman Kitchen Appliances - Others
The machine will not turn on, all the other buttons work, but I depress the start button and nothing happens, even tried holding it down, no results...
When you turn your machine be sure you choose a program (such as basic bread, usually #1 on most machines) After you do that then push start. Have you chosen your program and it still doesn't work?
Oct 11, 2010 | Breadman TR2500BC Bread Maker
Trying to change the intercom caller ID onthe M7324
Programming is done on 7310, 7324 and 7316 type sets.
Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow).
The display should now ask for an extension number. Enter extension number you want to change the name on.
Press the show key (top right arrow)
The display should say LINE ACCESS
Press the next key (bottom right arrow) .
The display should say CAPABILITIES.
The display say Name.
press the Chng soft key.
use the dial pad to enter the name. advance using the arrow soft key to go to the next letter
ex. Bill = 2,2 -> 4,4,4 -> 5,5,5 -> 5,5,5
Press the next key (bottom right arrow) to enter the name.
Press the release key when finished
Oct 23, 2009 | NorStar Meridian M7310 Phone
The machine (Automatic Breadmaker SD-255/SD-254) is plugged in and the display lights up but when I press the buttons but nothing happens - I cannot change the setting or start the machine.
Plug the unit in at the power outlet. If the display comes on, switch it off with the START/STOP button. After the display goes off, switch the unit on with the SELECT button. Remember that the START/STOP button is only used to start or stop a specific program.
Aug 02, 2008 | Kitchen Ranges
Sunbeam 5891 Bread Maker Logo
241 people viewed this question
Top Sunbeam Kitchen Appliances - Others Experts
Thomas Perkins
Thomas Perkins
ray gallant
Are you a Sunbeam Kitchen Appliances - Other Expert? Answer questions, earn points and help others
