Question about Samsung SCX-4300 Monochrome Laser Multifunction Printer
SCX-4300 Monochrome Laser Multifunction Printer: I unplugged the power cord, that didn't help. I bo...
I unplugged the power cord that didn't help. I bought the printer 1 month ago. Does this mean I have to buy a new fuser unit?
Anonymous
    New Friend:
  • 8 Answers
If you turn on the printer in the correct voltage, you can call the Samsung and ask to warranty. Now if the printer is off warranty period, test the fuser lamp in the same voltage of the printer.
Take off the fuser, disassemble then take off the lamp and connect two wires in each terminal of the lamp (Fuser lamp works on the same voltage as the printer and is "AC").
Plug the two wires in the power energy. If the lamp is ON, OK!! If not new fuser is necessary.
Posted on May 18, 2010
Xerox 7245
follow this instruction: God bless you
Instructions
    • 1
      Turn off the printer and unplug the power cord from the wall outlet. Wait at least one hour for the fuser assembly and other internal components to cool.
    • 2
      Open the back cover of the printer. Squeeze the two tabs located in the upper left corner of the back cover, then pull the cover off the printer body.
    • 3
      Push the two green tabs on the duplexer unit and pull the unit out of the printer. If your printer is not equipped with a duplexer, skip this step.
    • 4
      Remove the two screws on each end of the fuser. The screws are large enough to remove by hand. Grasp the orange tabs on the fuser and pull it straight out of the printer. Line up the new fuser and slide it into place on the track where you removed the old one.
    • 5
      Replace the screws on each end of the fuser. Turn the screws by hand until they are tight. Slide the duplexer unit back into place, pushing it into the slot until it locks in place.
    • 6
      Push the back cover back into place until it locks. Plug the power cord into the wall outlet and turn the power on to the printer.
Jul 20, 2013 | Xerox WorkCentre 7228 7235 7245 7328 7335...
My printer will not work it gives me system error 000
To resolve the issue, please try reseating the fixing assembly. To do so, please follow the instructions below:
1) Unplug the power cord from the wall outlet.
Caution: The fuser unit and surrounding area can become extremely hot during operation. Perform the following procedure after the fuser unit has cooled down completely. Touching the fuser unit when it is still hot may result in burns. skumar_sreen_0.gif
2) Turn the lock release levers located on the back of the machine in the direction of the arrow and release the lock. skumar_sreen_1.gif
Caution: The fuser unit weighs approximately 3.3 lb (1.5 kg), and it is heavier on the back side. Be sure to hold the grip securely when carrying a fuser unit. Dropping the unit may result in personal injuries. skumar_sreen_3.gif
4) Hold the grip on the fuser unit and install it securely. skumar_sreen_4.gif
5) Lock the fuser unit by turning the two lock release levers in the direction of the arrow. skumar_sreen_5.gif
6) Connect the power cord and all interface cables.
7) Plug the power cord in the wall outlet to turn on the machine.
Aug 30, 2011 | Laser Canon imageCLASS 8180C Multifunction...
Hello! my Samsung SF-565PR printer is now experiencing low heat error. it started late last month, from 13th month after purchase. i already tried unplugging and plugging it in. i read the manual and it...
in order to melt the dust ink the fuser must be at a certain heat if this rod blows then it will not work it should last a lot longer than it has but it would seem it has blown unless there is a power short up to it you will need to have it looked
there is no easy fix for this fault
hope this helps sir
Jan 03, 2011 | Samsung SF-565PR/XST Printer
How do I fix a transfer belt laser error? unplugging the power cord does not work What does this transfer belt look like? where is it located in my samsung CLX-2160N laser printer? thanks!
The transfer belt is a consumable like the toner, you will have to buy a new one once its run out so your printer is telling you it has so buy a new one. They look like a small conveyor belt from a supermarket and is generally located under the toner or fuser unit housing.
Mar 28, 2010 | Samsung CLX-2160N All-In-One Printer
What is error code E000 mean
Solution:
Press "Additional Functions",
Press "#", then press the "Right Arrow" button till it says, "Printer",
Then press "Set" then press the "Right Arrow" button again until it says "Printer Reset"
Then press "Set" again, the display will ask you "Yes" or "No".
Press the "Left" arrow for "Yes", then press "Set".
Now, unplug the power cord and wait 5 seconds and plug back in.
If this don't work, get a new fuser.
Feb 04, 2010 | Canon imageCLASS D880 All-In-One Laser...
I have a D7300 printer serial No Q7057B bought from Staples about 6 weeks ago. The message appears on screen: "Ink system has failed. Unable to print". I have turned it off and removed the...
Try this one:
Reset the Printer to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on.
2. Press and hold OK and HELP buttons while plugging in the power cord.
Now please unplug and re plug the power cable at the back of the Printer.
Hope that helps......
Aug 27, 2008 | HP Office Equipment & Supplies
Print
Check out these steps:
1. Connect the printer directly to the wall outlet and
1. Verify that the unit is switched on. Unplug the all-in-one from power and disconnect the connection port.
2. Wait 30 seconds.
3. Plug in the power only.
4. Repeat steps 2-4 two more times.
5. On the third time after plugging the unit into power, reconnect the connection port from the all-in-one to your computer.
Check with a copy from the front panel of the All-in-One.
However, the issue might be with the low on ink.
Please perform the following steps:
1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2. Then, press and hold # and 6 while plugging in the power cord.
Continue holding until it displays Semi Full Reset message in the front panel of the All-in-One.
Try to make a copy and get back to us with the results.
Regards,
Sagar
Aug 16, 2008 | HP Officejet 5610 All-In-One InkJet...
Low heat error
Low Heat Error
Cycle Power
There is a problem
in the fuser unit.
Unplug the power
cord and plug it back
in. If the problem
persists, please call
for service.
If this doesnt work call the fuser unit needs to be replaced.
Nov 02, 2007 | Samsung CLX 3160fn All-In-One Printer
Dell 1600N Multifunction printer problem.
Fuser issues - if problem is reoccuring then you are looking at more expense, are all vents free of obstructions (folders leaning on machine sides/rear) is machine being flogged, is power supply consistent, maybe even fuser bought was faulty, many options, try doing a warranty claim on fuser or replace again, even better get another printer, welcome to our throw away world!
Oct 31, 2007 | Dell 1600n All-In-One Laser Printer
Open Heat Error
the thermal switch on the fuser are damaged. my problem is that I don't know the temperature of activation to this. And do not buy a replacement under this conditions. somebody help me.
Sep 27, 2006 | Dell 1600n All-In-One Laser Printer
Samsung SCX-4300 Monochrome Laser Multifunction Printer Logo
148 people viewed this question
Top Samsung Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Muntejaya Ginting
Muntejaya Ginting
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
