Sirius KD-LHX500 CD Player: I checked the fuse in the back of the deck, and it...
I checked the fuse in the back of the deck and its not blown but whenever i turn on my car the decks lights on the buttons turn on but the screen doesn't work and neither does the sound.
try resetting your deck. the reset switch should either be an unmarked indentation about the size of a pencil tip on your face, or behind a small hole on the subpanel behind your face.
on your model there should be a small button on the lefthand side at the bottom of the detachable face that says reset, if you dont have a manual for this unit, i have got one i can send to you if you would like, just email me on [email protected].
i checked with 2 of my best installers and this will be the same part for your deck it will hook up threw the cd changer control located in the back of your deck
The Sirius Tuner is separate from the AM/FM/CD, check the plugs between the two. If all is snug, pull the SIRIUS tuner and go to a JVC dealer that would have any deck w/sirius as an option and plug it in. If it sees it, it's more than likely a problem with your deck. My guess is it's a bad SIRIUS tuner. There have been LOTS!!! Good news is there easy to replace if bad, and there cheap! $45.00 from Crutchfield rebuilt.
sometimes the micrprosser gets locked up and sometimes unplugging the radio for 2-3 minutes can reset the micro. if this does not reset it is possible that the micro would need to be replaced, if this is the case you would need special soldering equipment to change it, it would not be worth buying the solder station that you would [email protected]
try taking it all out and put it back in... That happened to me after I jump started my truck I took it out and just put it back in and it works fine now... just a thought
