Question about SanDisk Sansa e250 MP3 Player
Sansa e250 MP3 Player: won't play any music or change to any other format...
Won't play any music or change to any other format . Will not shut off
John Fourteen Six
  • 2,418 Answers
Hope this helps. See the section about the hot fix first----- If you are using Windows XP: you need the following. Windows XP SP2 or higher Windows Media Player 10 or higher Download and install the latest Windows Media Player if it's not installed. If you are using Windows Vista: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player. Download the hotfix from-->>> http://support.microsoft.com/kb/939211. Run the hotfix. Refresh the players driver Connect the Sansa player to the PC The screen on your player should turn on, show 'Connected' and indicate the battery charging or full. If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub. - If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working. If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. Check under Device Manager 1. Right-click My Computer, and select Manage. 2. Click Device Manager on the left pane. NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode. Exceptions are Sansa Connect and Sansa Express which only use MTP mode. MTP mode is the recommended and default method for Sansa Players when used with Windows OS. The Sansa player will show up on Device Manager's right pane as: 1. USB Mass Storage device (if the player is set to MSC) 2. Portable Device (if the player is set to MTP mode) If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers. Refresh the drivers 1. Right-click the entry with the error mark, select Uninstall. 2. On the top menu, click Action then select Scan for hardware changes. NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. Connect using MSC mode Connecting in MSC mode will help determine if there is a problem with MTP mode or with the Auto Detect mode feature of the player. You can use Forced MSC mode or switch the player settings to MSC. Instructions to connect in Forced MSC mode are listed here: http://kb.sandisk.com/app/answers/detail/a_id/61 Instructions to switch player to MSC mode are listed here: http://kb.sandisk.com/app/answers/detail/a_id/207 If the player is detected in MSC mode but not when set to MTP mode, try to update or reinstall the Sansa firmware NOTE: Sansa Express and Sansa Connect do not have MSC mode. For Sansa Connect you can try reinstalling the firmware using the Connect Recovery Mode. Additional troubleshooting notes: If you have replaced the Sansa Player and you still have problems getting it to recognize in the computer, then you may need to try some additional troubleshooting. - Try connecting on another computer. - Try using a different USB cable - Try connecting to the back USB ports which may supply better power. - If only MTP mode is not working, try reinstalling Windows Media Player For Windows XP try also download and install the MTP Porting Kit ........
Posted on May 19, 2010
Sansa e250 mp3 player won't recogize micro card
Make sure the card is a microSD card, not a microSDHC card. The e250 only works with microSD cards, 2GB and smaller.
Mar 19, 2012 | SanDisk Sansa e250 MP3 Player
Videos won't synchronize from windows media player to sansa e250 mp4 player
You need to use the supplied Sansa Media Converter program to convert videos (and photos) to a format the Sansa can handle. If you don't have the SMC, you can download the Windows version here.
Mar 19, 2012 | Audio Players & Recorders
Won't turn on
Please give some more details.
I suppose it's the problem that your Sansa e250 MP3 Player won't turn on.
You could turn to Sansa official support.
Jan 03, 2012 | SanDisk Sansa e250 MP3 Player
My mp3 player won't show me the pictures that I have uploaded on to it.
The player not support the photo file formats you have downloaded. Most MP3 players support jpg, bmp and gif image file formats.
Sep 10, 2011 | SanDisk Sansa e250 MP3 Player
Won,t play any music...
Hello.
Try to plug it into the computer.
Scan it to check if there's any possible virus.
And double click on it (My computer) to get it update.
May 19, 2010 | SanDisk Sansa e250 MP3 Player
My Sansa e250 wont let me put songs on it.
The songs are in the wrong format - you will have to load songs in mp3 format or WMA's THAT HAVE TRANSFER RIGHTS
Jan 11, 2009 | SanDisk Sansa e250 MP3 Player
How can i delete music file from my sansa e250
try formatting the player by selecting format from the properties menu when you right click it in my computer.
Aug 04, 2008 | SanDisk Sansa e250 MP3 Player
My sansa e250
If you want to delete EVERY track off the player, then reformat the player in Windows Media Player - it's a shortcut - see my "tips and tricks" on formatting mp3 players
If there are artist, album traces, then you need to click on every subfolder under your device in Windows Media Player and delete every trace that way - tedious, but effective
-Tha Mp3 Doctor
There are 2 ways to format an mp3 player - if you were formatting the mp3 player from "My Computer," then try reformatting from Windows Media Player instead - I have a "tips and tricks" entry on How to Format an Mp3 Player for details
If that doesn't work, then double-click on My Computer, double-click on the Sansa player, and go to the various folders that it lists - music, voice, etc. Delete the songs ONLY - do not delete the dat, bat, ini, inf, or other system files
Jun 04, 2008 | SanDisk Sansa e250 MP3 Player
Synchronize to continue your music subscription
Well...when ever I sync songs to my Sansa. I never change the mode and it syncs FINE! You should try it
Jan 11, 2008 | SanDisk Sansa e250 MP3 Player
Corrupted files
all i can say is try to format the mp3
Aug 06, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Jean Sintulaire
Daniel Dollive
Daniel Dollive
aliasger yq
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
