Question about Samson Concert 77 Professional Microphone
Concert 77 Professional Microphone: I have recieved samson Q7 dynamic mic as a present...
I have recieved samson Q7 dynamic mic as a present but it came by itself what do i need to purchase to hook it up to the stero system?
5 Related Answers
Anonymous
SOURCE: Samson C03 Microphone using with Realtek HD Audio Manager
SEU MICROFONE PRECISA DE UM RECURSO CHAMADO PHANTON POWER QUE NADA MAIS é DO QUE UMA ALIMENTAçãO DE 48 VOLTS, PORTANTO NECESSITA DE UM APARELHO INTERMEDIARIO, COMO UMA MESA DE SOM COM ESTE DISPOSITIVO OU UM ADAPTADOR PHANTON POWER COM SAIDA USB PARA O SEU PC, NO CASO DA MESA TAMBEM é NECESSARIO UMA PLACA DE AUDIO COM CONEXãO USB EXEMPLO UCA 202 DA BEHRINGER , PODES CRER Só ASSIM FUNCIONA E SOM é MUITO BOM.
Posted on Aug 06, 2008
Michial Gueffroy
  • 1140 Answers
SOURCE: Bought the Q7 mic .. doesn't work with my G-Dec Junior Fender Amp
If your amp has 2 inputs, you will need to rewire your standard mike cable as follows. Go to http://s3.amazonaws.com/samsontech/related_docs/Q7_ownman_v1s.pdf for the wiring diagram. If you aren't comfortable with doing this go to a music store and explain your problem and ask if they have a low to high impedance adapter with an XLR on one end and a 1/4" plug on the other. Hope this helps.
Posted on May 23, 2009
Fred Yearian
  • 5603 Answers
SOURCE: whistling background noise with Samson C01U USB condenser mic
Welcome to the world of STUDIO microphones. Super quality BUT you must have a studio to use them. You can't have any local speaker playing into them. You often use headphones lest your monitor speakers will feedback. At the high frequency capability of these mics, you can fry your amps with oscillations above what you can hear!
Posted on Sep 30, 2009
Fred Yearian
  • 5603 Answers
SOURCE: change the samson airline 77 microphone for a AMT, for sax player
Unfortunately, you don't have enough information to go on to give you a definative answer.
The Sampson Aireline will plug onto ANY xlr type DYNAMIC mic and should work.
The one thing on the AMT Elite I found said it was a "condenser" type element which means it would NOT work with your Sampson setup. Condenser mics require a Phantom power arrangement to charge the element and operate the local FET input amplifier.
If you are trying to mic a violin, the Airline 77 that was for the dynamic mics is a very poor choice as it is low impedance. Most violin pickups use a Piezo pickup which requires VERY high impedance input amplifier.
For my wife's violin we use an Autolycus pickup and an X2 wireless sytem. The pickup comes from New Zeeland and the X2 is CD quality digital wireless link. You have to make your own connector at the violin for the X2 cable was intended for guitars.
Posted on Dec 25, 2009
SOURCE: I own a Samson Synth
Hi, Radio Mic's can be great tools, but are devils for going faulty. They generally use an Electret Mic, this Mic requires Power to make it go. (Many problem are caused by Bad batteries, so these must be checked, and ideally swapped for known good ones. Also Check the battery connector too, it must be intact and clean and shinny, give it a rough up with sandpaper if unsure. Another point of failure is the On/Off switch, the battery side connection often comes off, and needs to be re-soldered) Anyway the signal from the electret. this then drives the FM transmitter, and the received signal is decoded, and you can hear it.
Now, you say that there is a "pop" when it is switched ON, well this at least gives us some hope, It is very ODD that BOTH of them are "Faulty" ? I would tend to look elsewhere? IF after you have checked out all the points I raised above, are attended to. and the Mic's check out OK. Maybe they have drifted off frequency, often there are trimmers inside the receiver to adjust..
Now these units can be obtained on eBay and the like very inexpensively indeed. As for repair again, eBay is the best.
If you can tune the transmitter, or know the frequency to tune the transmitter to. Now, then what I have done in the past is obtained a FM Transmitter Mic, kitset, made the kitset up, and then ripped the "Old" electronics out of the :"Old" mic housing and shoehorning in the new working kitset. tuned into the Receiver.
Always get a pair working standalone first, then after you get the Mic working out through the receiver, then, and only then use the receiver with "Other" things.
Posted on Aug 25, 2010
No sound Samson airline 77
So, if I am understanding you right. As you are talking on the mic you are cutting out as if it is shutting down. If this is the case I would adjust your settings. It sounds like it is clipping from maxing out the input. A protection is cutting you out. Let me know if this is not the case.
Jan 20, 2013 | Samson Airline 77 Professional Microphone
How do you hook up asamson concert 77 wireless system to speakers
No that doesn't work because the headphone jack on your receiver is a output. You need a input like the AUX, so you need a adaptor from jack to cinch.
Regards,
Gerard
Jul 09, 2012 | Samson Concert 77 Professional Microphone
Hey recently bought samson Q7 mic nd wanted to know wat do i need to connect to my computer
A sound card like an MBox or something like that will do it. Or a small desk with a USB out or if your computer has 3.5 in then any small mixer will work with some adapters.
Jul 01, 2011 | Samson Q7 Professional Microphone
I purchased a R31S Samson Microphone and it cant be detected when i plug it in to my computer microphone jack. What is it to do?
A dynamic mic connected to the your computer's mic jack is an analog connection. So your computer won't give a notification that there's a mic connected. However, you can view input levels through the default windows mixer of your sound card or any program or application installed on your computer that has the capability. Had it been connected through usb or firewire, it would be digital and you wold be notified that the device had been detected via device drivers etc.
Hope this helps
Apr 09, 2011 | Samson R31S Microphone
I bought a samson se50 headset microphone to go with my GTD Audio wireless system. It has the correct adapter plug to plug in to the transmitter. The plug is a mini XLR plug. The microphone does not...
You need power from the transmitter to power this mic. See your mics specs to determine if it needs "Phantom Power"
Perhaps the transmitter doesn't supply power. Condenser mics may not work. Stay with the dynamic type. IMHO
Jul 29, 2010 | Nady Systems Nady ATM-75 Headset Mic w/...
I just today bought a Samson R21S microphone, and I plugged it into my laptop via the laptops microphone jack, and immediately had problems. It cuts off my voice in mid sentence, it wont get half of my...
Not really the mic's fault - just incompatible.
Your Samson mic is a "dynamic" type and the laptop is expecting a "condensor" type.
You could put the mic through a preamp first but easier to exchange for a more suitable type.
Hope this helps.
http://stores.ebay.co.uk/methleykev
http://www.technicsdjuk.com/
Jul 09, 2010 | Samson R21S Microphone
The Cartridge broke loose inside the screen. Are the Q7 mics serviceable.
You can try to glue the parts together, but only if the wiring is not broken.
Regards,
Gerard
Mar 02, 2010 | Samson Q7 Professional Microphone
Change the samson airline 77 microphone for a AMT, for sax player
Dec 21, 2009 | AMT Datasouth Violin, Viola, & Mandolin...
May 23, 2009 | Samson Q7 Professional Microphone
SAMSON STAGE 5 (BASS)
i have the same prob but i use concert 77
Aug 31, 2008 | Samson AirLine Guitar - Wireless System...
Samson Concert 77 Professional Microphone Logo
124 people viewed this question
Top Samson Audio Players & Recorders Experts
 Grubhead
Grubhead
ray gallant
Are you a Samson Audio Player and Recorder Expert? Answer questions, earn points and help others
