Visit the motherboard manufacturers website for the drivers you need. Even if you don't use the RAID function the hardware is still built on the motherboard and you will need the drivers for windows to communicate with the hardware correctly. You might also find the drivers on the "Driver" CD that came with the motherboard.
Sounds like you need some drivers, I assume all the connectors are correctly in place. If you can goto your device manager and see if there is a small yellow triangle with an "!" in the middle. Right click on this and search for drivers. If that doesn't work it'll be your chip set drivers. Look on the motherboard or use a program like CPZ to find out your motherboards model, go on HP's website and find the dirver. install manually.
first you need to prepare the scsi drives ie host raid adapter scsi drivers are server raid cotroller 6 scsi drivers by using the serevr raid support cd dikettitools proper os drivers to floppy and boot with widows cd at the time starting boot press f6 to specify the scsi drivers then all scsi hdd will detect for installatio.
If you're using a scsi card and connecting the hard drive to the card you need to have the scsi set-up floppy disk. When the blue screen starts during windows installation watch the bottom of the screen. It will tell you to press F6 key then to insert the floppy disk.
If you're using a sata drive connected directly to the motherboard (not in a raid configuration) you shouldn't need anything but the windows disk. The motherboard drivers and utilities disk should have the files to create the scsi install disk.
Did you see any new drives in the disk managemen screen? To get to the disk management, hold window key down and hit 'R', then type diskmgmt.msc and hit enter.
If you do see the drive in the lower half of the screen, you need to initialize the drive either as dynamic disk or basic disk. Then you need to add a new partition and format it.
You have apparently attempted to attach a tape drive or other similar device to a SCSI RAID controller. You will need to get a separate SE SCSI HBA instead. These are pretty cheap, usually just over $100 list from HP.
If you haven't attached anything new, then you should check your cables first and if that doesn't help I would suspect a bad RAID controller.
That particular work station comes with both IDE and SCSI drive interface controllers. The IDE drive should be used for your OS. The SCSI drives for your data storage. Now, the issue is to get the SCSI to work in RAID_0 as I understand.
You iwll need a RAID controller such as Adaptec AHA-3940AU WD SCSI Host Controller, which may be found on eBay (used) for a very affordable price. The driver software may be downloaded directly from Adaptec, so I suggest you do that in the iterim peroid, and store drivers on a USB thumb drive.
