There are many places and parts for dirt to remain after washing. Clean all parts as per manual. Spray inside with vinegar and lemon juice, place tablespoon of bi-carb soda in dispenser and put through cycle without dishes
You need to check the drain system completely, look for plugged screens, pump impellers, valves and the drain hose. You need to witness a large volume of water flow during drain.
generally dishwashers rely on the pressure supplied by the water supply line. check to see if it is enough or if inlet pipe is of sufficient diameter for needed flow.in some instances i know of seperate lines needing to be run directly instead of coming off of supply to sink area.
