Most likely the problem is that your computer is trying to boot from your external hard drive and that why windows 7 wont start up but it is a very easy fix. with the freeagent attached start up your computer system and when the first BIOS screen is displayed press either the F8 key or the ESC key to enter BIOS setup it should say on the screen which button you need to press. Once you press the correct button the BIOS set up screen will load there should be tabs at the top and select the boot tab, under the boot tab there will be a list of devices in the order that the computer will try and boot off of them all u need to do is move your freeagent to the bottom of the list and every thing will work perfect.
I hope this helped.
Thank you,
Norse
Testimonial: "Advice was good however this method was tried without success. Excellent contributor."
Thanks Norse, however the BIOS was already checked and is listed like you state. According to HP, this is a known problem with the Seagate external. Do you know if I can switch this Seagate Freeagent Classic to a firewire connection?
Thanks for your assistance!
