Dear User,
I am sharing with you the following objects to help you achieve your desired results,
1. Service manual of your printer to understand the problem
2. A link to step by step, with pictures to understand how it is done for a Samsung printer (will help you understand the process)
Link 1. : http://diagramasde.com/diagramas/otros/SF2025_SERVICIO.pdf
How do you do. You should check join from the main of the charge to device сортера.If connections is checked and where are no mistakes in join no pay attention to mechanical possible damages, findings scrap papers and stranger subject in sorter device. Recall, pr what circumstance appeared the fault.Error code F1 for sharp copiers sf 2020.2030
Sub code 00: Communication error between main board and sorter. Sub code 02: Sorter transport motor drive.
First you need to know the key operator code, you can display it by pressing [C][INTERUPT] [0/ZERO][INTERUPT][22][START][13][START] then the display will shows you the 5 digits key operator.
After you know the key operator code, you can go to User program, this is done by pressing [C][INTERUPT] [C] then input the key operator code, when entry is complete "P" will appear in the quantity display. Input 19 then START, input the new code and press START. To exit user program press CA
F1 FIRST OF ALL CHECK WHAT IS THE SUB CODE .IF SUB CODE IS 00 ITS COMMUNICATION ERROR BETWEEN MAIN BOARD AND FINISHER.IF 01 FINISHER SHIFT PROBLEM.IF 06 FINISHER MOTOR PROBLEM.IF 10 THAT IS STAPLER PROBLEM.DO NOT FORGET TO RATE THE SOLUTION.MIAN JEE
