Washing Machines Logo
Zanussi zwf 1430s,power going to machine but when button pressed green light does not come on just a red light nothing on display panel
Posted by hgselectrica on
Anonymous
    Sergeant:
  • 198 Answers
Count how many times the red light flashes and how many the green light flashes.If its 1 green and 1 red thats water problems.If 2 flashes of red light check filter is clear and pump is free to turn.
Posted on Dec 02, 2012
Anonymous
  • 269 Answers
Hope this helped.
Posted on May 18, 2010
Zanussi machine washer. ZWF 1000M The wash button is red. The rinse button, spin button, and power botton is flashing red. This happened several minutes after tuning oN the 30 min cycle.
According to your description it is a failure E9- motor is not working. The temperature rises too high. The motor cut off for heat safeguard (Harness failure, PCB failure).
Dado
My zanussi zwg 6141p washing machine is calling water at start of cycle but is not going into drawer to swill out detergent , is also stopping half way with the green light on the start button flashin
Some appliances malfunction can be displayed in hexadecimal or in binary code.
So your device is defective and shows you what's wrong. You have to count how many times flashes red light and how many times flashes green light. Red light shows the first error number and green light the second error number.
For example: you forgot to close the door and you started washing machine. After some time (timeout) will generate an alarm. Four times will flash red light and once the green light which means error code " E41 " or "Open door"
" E20 " means "No drain water"
" E10 " means "No fill up water"
Dado
Why do i get 'err on display and buttons do nothing
err is error......should be a number or code after err.......
cheers
Zanussi ZWF580- after the wash cycle I press the red button to rinse & spin but it just tumbles & rinses again, then the red button comes on again. This could go on all day. I find that to finish...
If the START / PAUSE button lights up red, the washing machine detects a malfunction. Now you should count how many times the START / PAUSE button lights up red and tell to us what kind of malfunction is being done.
Try to rapid reading of alarm codes when the appliance is in normal operating mode (e.g. during the execution of the washing
programme):
Press and hold down START/PAUSE and the nearest option button for at least two seconds: the LEDs initially switch off, and then display the flashing sequence indicating the last alarm.
LED indicator START / PAUSE with red light = indicates the first digit of the alarm code (family)
• LED indicator START / PAUSE with green light = indicates the second digit of the alarm code (internal number of the family)
Dado
Zanussi TCE 7276W Condensor Dryer - no red lights but won't go!
Hello, have you cleaned the condensor stack just recently if so check that the stack etc is fitted correctly and the door is closed fully.
Hope this helps.
May 14, 2010 • Dryers
Zanussi ZWF 1430W Err message displayed and all buttons locked.
I am not a repair professional. I am just a 78 year old man who has been making his own repairs for about 50 years. Therefore the washer ID doesn't mean
anything to me. It's been about 55 years since I had experience with front load washers. However I can refer you to www.applianceaid.com where they have very good and complete trouble shooting and repair information on front loaders. I think you'll find what you need there. Don't worry about the timer, they hardly ever go bad. Good luck with it. If I have helped you, please rate my advice on fixya.
Zanussi ZWF 1631W
Try to pull out the power-cable from the contact. Wait for at least 30 seconds then reconect it again.
Sometimes that can help but not always. If that dosent help you need to let a profesional repairshop fix your machine.
Good luck
PROBLEM
Its your filter that needs to be emptied; open up the front, locate filter, clean out. Refer to users' manual.
Open Questions:
Top Washing Machines Experts
Marvin
Marvin
john h
