Question about CyberLink PowerProducer 2 for PC
I have a file with 931 MB but when it added using cyberlink power producer it shows that it is 7041 MB in size and not burning and showing the size of the imported files exceeds the amount of available disk space . which formats it supports and avi format is not supporting. I have installed using LG DVD came with writer
Posted by pabbu_432 on
5 Related Answers
Anonymous
  • 432 Answers
SOURCE: my power dvd not playing dvd with udf file system
use windows media player classic or VLC ( http://www.videolan.org/vlc ) if those work then it is obviously the installation of power dvd - in which case I would re install it and try again
Posted on Apr 10, 2009
Anonymous
  • 432 Answers
SOURCE: how to get support software to run udf file system dvds in power
you already have this question posted and answered here http://www.fixya.com/support/t1965217-power_dvd_not_playing_dvd_udf_file
Anonymous
SOURCE: Failure while importing videos
is it because i dont got the original version? so i can't import videos with more than 30min?
thank you
Posted on Apr 28, 2009
Anonymous
  • 433 Answers
SOURCE: I have burn a DVD video using Cyberlink DVD Suite
There are many DVD formats DVD- DVD+ DVD-ROM heck even blueray is a different DVD format.,Now see if you can find any paper work for your DVD stand alone and see what is compatible with it.
The only other thought it may be, in your burning program you can select to have the DVD play only on the computer you make it on...see if that is checked
and if it is make so DVDs can play in all players.
So to recap: a compatibility issue or a proprietary setting for your computer only.
hope this helps, please leave rating, thank you
Posted on May 11, 2009
Siouxie
Siouxie
  • 100 Answers
SOURCE: PowerProducer3 'failed to add video file'
I solved this problem by using a different program as I could not resolve the error with the cyberlink software.
Posted on Nov 17, 2009
I get the message when i try to copy a CD ,,out of memory
Your virtual memory is low this is not a real problem when you have other things running in the background you do not know about. I usually increase my memory as well as when I burn things I have no windows open email automatic checking turned off as well as power options stopped so I can get a clean burn no glitches as well as it may take a bit longer but I use the slower speed rather than the fastest speed burning never fails when I do this.
How to manually change the size of the virtual memory paging fileYou must be logged on as an administrator or as a member of the administrator's group to complete this procedure. If your computer is connected to a network, network policy settings may prevent you from completing this procedure.
To manually change the size of virtual memory, follow these steps:
  1. Click Start, click Run, type sysdm.cpl in the Open box, and then press ENTER.
  2. Click the Advanced tab, and then under Performance click Settings.
  3. Click the Advanced tab, and then under Virtual memory click Change.
  4. Under Drive [Volume Label], click the drive that contains the paging file that you want to change.
  5. Under Paging file size for selected drive, click Custom size, type a new paging file size in megabytes (MB) in the Initial size (MB) or Maximum size (MB) box, and then click Set.
  6. Click OK to close the dialog box and apply changes.
Note After you change the size of the paging file, you may be prompted to restart Windows. If you are prompted to restart, the changes will not take effect until Windows is restarted.
Notes
  • To have Windows select the best paging file size, click System managed size. The recommended minimum size is the same as 1.5 times the RAM on your computer, and 3 times that figure for the maximum size. For example, if you have 256 MB of RAM, the minimum size is 384 MB, and the maximum size is 1152 MB.
  • For best performance, do not set the initial size to less than the minimum recommended size under Total paging file size for all drives. The recommended size is the same as 1.5 times the RAM on your computer. It is good practice to leave the paging file at its recommended size as performance can decrease if a paging file is too large. However, you may increase its size if you frequently use programs that use lots of memory, such as graphics programs or games.
  • We strongly recommend that you do not disable or delete the paging file because this can lessen the computer's performance. However, if you decide to delete a paging file, set both the initial size and the maximum size to zero, or click No paging file.
How to manually optimize the memory usageYou can optimize your computer's memory usage to reflect your specific needs. If your computer is used as a workstation instead of as a server, you can increase performance by devoting more memory to your programs. Your programs will work faster and the system cache size will remain the default size that was included with Windows XP. Or, you can set aside more computer memory for a larger system cache if your computer is used primarily as a server, or if you use programs that require a large system cache.
  3. Click the Advanced tab, and then under Memory usage use one of the following methods:
    • Click Programs if you use your computer primarily as a workstation instead of as a server. This option allocates more memory to your programs.
    • Click System cache if your computer is used primarily as a server or if you use programs that use a large system cache.
  4. Click OK to save preferences and close the dialog box. I hope that this assisted you thanks for using FixYa! John
Feb 23, 2011 | CyberLink Power2Go
Creating dvd from JVC Everio
What kind of file is stored on computer, what extension (eg *.avi)
Jun 01, 2008 | JVC Everio GZ-MG21 Camcorder
I have been using Cyberlink Powerproducer Express for many years which after producing the appropraye files, it passes down to and opens Cyberlink - Power Producer 2 Gold to generate the DVD. For some...
If recently you have made any hardware or software changes eliminate that and then check how it works.
Do system Restore to a previous date when your computer was working fine to do that go to Start - all programs - accesories - system tools - system restore select a date when your computer was working fine follow the on screen steps.
if you have win vista then start-search type system restore and do the same thing.
If this doesnt helps try to uninstall and reinstall the software.
Jul 25, 2010 | CyberLink PowerProducer 2 for PC
I have edited a video with Cyberlink but when I go to burn it to disc, cannot find the file in PowerProducer / 5.0
Go to Start->Search and type the name pf this newly saved file in the All Files and Folders and start search. Windows will show you the name of the file and the folder where it is saved.
Oct 20, 2009 | CyberLink SW- DVD Software Power DVD...
Failed to burn DV disc.Cyberlink Media Show error code 0x0A180001
I was also suffering this problem with Nero 6. To solve your Problem first make sure that the windows you are using that supports your Software if supports, then your Optical Drive may not Write in high speed 16x or 18x, write your files in DVD in little bit slow speed, after doing all this if it gives same problem then Please reinstall your windows you are using.
Mar 08, 2009 | Computers & Internet
Where can i get freeware/shareware copy of power producer 2 gold from please
Power Producer Gold 2 is not a shareware/freeware program; it's a commercial, off-the-shelf product from CyberLink. It is video-editing software and is used for home moviemakers looking for a user-friendly program. PowerProducer 2 is compatible with many movie formats and can double as a digital photo album. It's generally available at around $69.95. It won't add incredible graphics or Hollywood special effects to your movies but it's a reliable and simple system for capturing video, cleaning it up with editing tools, and burning the end product onto CD or DVD.
I don't know if Power Producer 2 Gold is available becaue Power Producer 5 is on the market. You can get more information on buying it at www.gocyberlink.com
Let me know if this helps.
[email protected]
I believe it's available for about $69 from sold by CyberLink
Dec 10, 2008 | CyberLink PowerProducer 2 for PC
Hello, I am using cyberlink power producer slide show & i would like to add multiple background music. How can I do that? I am able to add one song.
Use the DOS copy command to append a bunch of MP3 files together, and then use the one combined file. It works best if the MP3 files all have the same characteristics (volume, bit rate, etc.)
In the command prompt, go "copy /b one.mp3+two.mp3+three.mp3 combined.mp3"
Dec 01, 2008 | CyberLink PowerProducer 2 for PC
Just a video of 8.03 minutes captured in my Power Shot A550 Digital Camera shows 867 MB size
A 1.3 hour movie is recorded on a DVD, not a CD. DVDs can hold a minimum of 4.7 GB, or nearly seven times the capacity of CDs. Your 867 MB file of 8.03 minutes indicates that you were recording at about 1,800 KB/sec, or the highest quality recording level. (See specifications here.) If you're willing to record your video in a smaller size, you can get much more recording on a CD.
Apr 30, 2008 | Canon PowerShot A550 Digital Camera
No space left even though all files deleted
format your player but make a back up of your music.
Aug 31, 2006 | Lexar LDP-400 MP3 Player
File size on DSC-M1
The files are compressed. A typical 5mp file should be around 2.5 Mb in size. A 7mp camera produces a file of abot 3.5 Mb.
Sep 15, 2005 | Sony Cyber-Shot DSC-M1 Digital Camera
CyberLink PowerProducer 2 for PC Logo
159 people viewed this question
Top CyberLink Computers & Internet Experts
Lee Hodgson
Lee Hodgson
ThaMp3Doctor
ThaMp3Doctor
Are you a CyberLink Computer and Internet Expert? Answer questions, earn points and help others
