Gestetner DSm725 Color Copier Logo
Posted on May 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
We have a fuser unit that is out on our machine. I saw a Ricoh replacement part that fits this unit, do you recommend we purchase it? Also, how do we go about replacing the fuser ourselves?
Anonymous
Level 3:
President:
  • Master 3,085 Answers
  • Posted on May 18, 2010
Anonymous
Master
Level 3:
President:
Answers
3085
Questions
Helped
1007097
Points
9738
Open the door on the left side
Remove the colored thumbscrew
Move levers down
Remove then install new fuser
Help need for getting rid of SC 544-00 on a Ricoh SP C830DN machine.
SC 544 is a fuser overheat error. This could be caused by power outage or fluctuation in the power.
go to service mode. Hold down both "home" and "simple screen" for about 5 sec. and then press "user tools"
once in service mode go to SP5810 reset fuser error.
and reboot the machine.
2answers
Sc544 on ricoh 1075
You have a fuser error, you will need to repair the fuser unit or replace it, can be the thermistors, thermalfuse or heat lamp, then you'll need to reset the machine via service mode, strongly recommend to be repaired by a technician. Good luck.
I have a Ricoh CL7100 printer. It has for some time displayed a red error lamp and a message "replace fuser oil unit (type g)" I was advised a while ago that I could continue to use printer (and have...
OPEN FRONT DOOR OF COPIER LEFT SIDE SHOULD BE A CLEAR CONTAINER WITH OIL IN IT. THAT IS WASTE OIL FROM FUSER. HAS FILLED UP. EMPTY IT OR FIND A RICOH DEALER THAT CAN SELL ONE TO YOU. try ebay saw one on there
How to refill oil Fuser at unit at Ricoh Aficio 2232c/2238c
These machines use oil supply units located on top of the fuser unit. They are not refillable order another and replace... continueing to run this machine without fuser oil will cause the fuser to fail and copies to look terrible
13helpful
4answers
Ricoh Aficio 2238c: Fuser Oil Unit
you really can not refill the bottle but I would recommend two things. One find a fuser oil unit on ebay and order it quickly. Next hit the yellow clear modes button, then hit the numbers 1 0 7 , then hold the red clear stop button till the display panel changes. hit copy sp, select 7 data log. now use the page down arrows located in the middle of the disply till you see 7804 push it then go to #10 oil supply and hit execute. this will reset the oil counter and allow you to use the machine till you get the new unit.
Top Gestetner Office Equipment & Supplies Experts
Daniel Blask
Daniel Blask
ZJ Limited
ZJ Limited
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
