Question about Activision Call of Duty Modern Warfare 2
Error creating session. wind i go online or multiplayer willnt read or go online
Posted by hooksd33 on
Anonymous
    Scholar:
    New Friend:
  • 27 Answers
Hopefully this will help solve your problem:
1. Press and hold down the power button located at the front of the PS3 console, until you hear a first beep, then eventually a second – before the console shuts down, then let go of the button;
2. Now press and hold the button again until you hear a first beep, then a second beep then eventually a quick double-beep, then let go of the button;
3. The TV screen should now display a six option menu, where you can select what’s required, i.e. `Restart System`, `Restore System` etc. `Reset System` should only be used after other attempts with the other options, as your game saved data may be lost. If you play Modern Warfare 2 online, then this won’t be affected as your data is saved on the Sony Server.
4. During any of the above actions, your best having your handset controller connected to the PS3 via the USB cord, which includes pressing the `P` button when required (located between `Start` and `Select`).
These actions should help solve `freeze` problems and others such as update errors etc – which restrict you starting up or playing your console.
Don’t hesitate to contact Sony UK if required, who are very helpful. Their UK number is: 0844 7360595
Good Luck!
Posted on Jul 04, 2010
verifiy ssid/wep wireless settings either from the router or your internet provider Likely cause: It appears that the settings entered into the Nintendo DS are not compatible, or the router's broadcast settings should be changed.
How to fix: Try creating a new connection with your system. Nintendo DSi owners trying to play multiplayer games will want to be sure to read the "Trying to play online multiplayer with Nintendo DSi."
  1. Create a new connection: This error can occur if a setting (like your network's name) has changed since you last connected. If it's been awhile since you connected, or if this is your first time connecting, creating a new connection file will often resolve this error code. Click the button below for your system and we'll walk you through the connection step-by-step
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=051099&system=DS&locale=en_US
Jan 12, 2013 | Computers & Internet
I have a error code and the number is 0510991
Source: http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=051099-1&system=DS&locale=en_US
Jul 31, 2011 | Nintendo Dsi Pink Console
How do you get the internet on this my says no compatible access point in range check your connection setting under internet opion and try again error code 051099
Unable to use your wireless signal
  1. Create a new connection: This error can occur if a setting (like your network's name) has changed since you last connected. If it's been awhile since you connected, or if this is your first time connecting, creating a new connection file will often resolve this error code. Click the button below for your system and we'll walk you through the connection step-by-step.
Even if you are able to connect online and use other online features of the Nintendo DSi, if you are attempting to play multiplayer games but are receiving error code 51099 when you try and connect, then your router is likely using a security type - WPA - that is not compatible with Nintendo DS Game Cards.
Try this:
If you are sure you are using WPA, click here for more information including alternative connection methods. If you're not sure if you're using WPA, you can find out by going into the connection settings on your Nintendo DSi and doing a search for an access point. Follow these steps:
  1. Turn on your Nintendo DSi and access the System Settings by clicking on the wrench icon
mr_fix3er_0.png 2- Scroll over to the third page, and select "Internet."
mr_fix3er_1.png 3-Now choose "Connection Settings."
mr_fix3er_2.png4-Click on "None" for "Connection 1."
mr_fix3er_3.png 5-Click on "Search for an Access Point."
mr_fix3er_4.png 6-The Nintendo DSi will search for any wireless networks within range. Once it is finished searching, it will display the names of all the wireless networks it finds. Look for your wireless network.
7-What to do next will depend on the "lock" icon you see next to your network on the Nintendo DSi.
mr_fix3er_5.png No security - This connection type is compatible with Nintendo DS Game Card online multiplayer.
mr_fix3er_6.pngWEP - This connection type is compatible with Nintendo DS Game Card online multiplayer.
mr_fix3er_7.pngWPA - This connection type is not compatible with Nintendo DS Game Card online multiplayer. Security will need to be changed to WEP or turned off in order to play online. Click here for more info.
  • Other suggestions :
  • Make sure your router is set to broadcast in "b" or "mixed" mode. If your wireless router is transmitting in "N" only mode, you will need to switch it to "b/g" or "mixed" mode. For help accessing your router's settings, click here and select your router brand and model (if available). Most routers will have this setting in the "broadcast settings" menu.
    • Check for wireless interference, which can affect the signal strength to the Nintendo DS. To help minimize wireless interference, try the following:
      • Make sure other wireless devices such as cordless phones or wireless speakers are turned off, and that the Nintendo DS is an open area without objects or electronics blocking the signal.
      • Change your router's channel setting to 1 or 11. By default, most routers broadcast on channel 6, which overlaps with other channels and may be weaker. For help doing this, click here and select your router brand and model (if available). The information you need is found in the "Broadcast Channel:" area.
  • Still stuck? We can help! We have found that simply erasing the old connection file and creating a new connection to your router may help. Click the button below for a step-by-step guide. If at the end you still need help, you'll find contact information to reach our specially-trained representatives. Click the button below for your system and we'll walk you through the connection step-by-step.
    Apr 14, 2011 | Nintendo DSi Matte Blue Console
    Whenever I try to do a LAN multiplayer game it will say Session Creation Error
    I was able to create a LAN game, and to see the game in the list in the another computer, but this one is unable to join the game, it starts usin all the CPU power. What I did to reach this situation, instead the "session creation error" was to install a required protocol: Control Panel - Net conections - (the conection that you use (double click)) - properties - install - protocol - NW Link IPX. Hope it to help a bit.
    Mar 14, 2011 | NovaLogic F-16 Multirole Fighter for...
    No compatible access point in range - error code 51099
    The Following website lists your Error Code. Per Nintendo:
    "Likely cause: It appears that the settings entered into the Nintendo DS are not compatible, or the router's broadcast settings should be changed.
    http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=51099&system=DS&locale=lang
    Mar 10, 2011 | Nintendo DS Lite Console
    More information can be found at: http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=051099&system=DS&locale=en_US
    Feb 27, 2011 | Nintendo DSi XL Burgundy
    I tried to contact the internet and it keep on saying your error code 051099 and i wanted internet
    Hi tabia tabz, Nintendo has an excellent walk-through on fixing just that issue. Instead of just re-ryping their information I will post it exactly as they had it because they offer very nice images of exactly what you need to do each step which should help you alot.
    Here is what Nintendo states:
    Error Code: 051099 Was this information helpful?Unable to use your wireless signal
    2. Trying to play online multiplayer with Nintendo DSi
      Even if you are able to connect online and use other online features of the Nintendo DSi, if you are attempting to play multiplayer games but are receiving error code 51099 when you try and connect, then your router is likely using a security type - WPA - that is not compatible with Nintendo DS Game Cards.Try this:
      1. Turn on your Nintendo DSi and access the System Settings by clicking on the wrench icon.
      2. Scroll over to the third page, and select "Internet."
      3. Now choose "Connection Settings."
      4. Click on "None" for "Connection 1."
      5. Click on "Search for an Access Point."
      6. The Nintendo DSi will search for any wireless networks within range. Once it is finished searching, it will display the names of all the wireless networks it finds.Look for your wireless network.
      7. What to do next will depend on the "lock" icon you see next to your network on the Nintendo DSi.
          unlocked.png No security - This connection type is compatible with Nintendo DS Game Card online multiplayer.
          lock_compatible.png WEP - This connection type is compatible with Nintendo DS Game Card online multiplayer.
          lock_wpa.png WPA - This connection type is not compatible with Nintendo DS Game Card online multiplayer. Security will need to be changed to WEP or turned off in order to play online. Click here for more info.
    3. Other suggestions:
    Feb 23, 2011 | Nintendo Dsi Pink Console
    Error code 051099"1 nintendo dsi.trying to get
    Error Code: 051099Was this information helpful?
    Here's a link:
    http://www.nintendo.com/consumer/systems/wii/en_na/errors/index.jsp
    DONT FORGET TO RATE THIS PLEASE
    Jan 30, 2011 | Nintendo DSi Matte Blue Console
    How to i get to play two players on the Nintendo ds lite
    You can play multiplayer games with a Nintendo DS Lite even if you don’t possess a copy of the game. If one of your friends has a multiplayer game card, they can use their Nintendo DS Lite as a host for the game session and you can join the multiplayer game.
    jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); });
    Things You'll Need:
    • Nintendo DS Lite
      Using One Card to Host the Game
    1. Step 1 Look on the game’s packaging for the "Multiplayer" icon. If the game requires only one player to have a copy of the game, the icon will show two DS Lites: a DS Lite with a black screen transmitting waves to a DS Lite with a white screen. Below the two DS Lites is a range of numbers which indicates how many players the game can support.
    2. Step 2 Put the game card in the Nintendo DS Lite that is acting as the host for the multiplayer game session and start it up.
    3. Step 3 Have the other players turn on their systems. They will use the main menu screen to access the "DS Download Play" icon. They need to tap the icon to begin downloading the game information from the host DS Lite.
    4. Step 4 Begin playing when all of the systems have finished downloading the game information from the host.
    5. Multiple Cards for Multiple Players
    6. Step 1 Look at the "Multiplayer" icon. If every player in the game session needs a copy of the game in order to play, the icon will show two DS Lites, both with black screens, transmitting waves toward each other. A range of numbers is under this graphic and indicates how many people can play at one time.
    7. Step 2 Read the game's instruction manual on how to set up the game session. The steps required vary by company and sometimes by title within the same company.
    *reposted from ehow.com
    Jun 21, 2009 | Nintendo DS Lite Console
    COD4 Multiplayer makes computer fans loud and hot.
    When you play online games it will usually require more system resources to power. Your processor also handles the data that is being sent and received during your online session. Some code for online games have more overhead than others. I do not believe that it has anything to do with your machine, but more the software and network overhead that the multiplayer game requires. If you notice that both single and multiplayer run on seperate executables...
    Single Player = C:\Program Files\Activision\Call of Duty 4 - Modern Warfare\iw3sp.exe
    Multiplayer = C:\Program Files\Activision\Call of Duty 4 - Modern Warfare\iw3mp.exe
    Hope this helped!
    Apr 24, 2008 | Dell Inspiron 6400 Notebook
    Activision Call of Duty Modern Warfare 2 Logo
    Top Activision Video Game Consoles & Games Experts
    ray gallant
    Tom Chichester
    Are you an Activision Video Game Console and Game Expert? Answer questions, earn points and help others
