I have an older Quasar Television, and I don't have the remote to get rid of the closed captions (cc) in Spanish. Is there any other way to turn this off my television? Carolyn Hendry
Did you try turning it off with the closed caption button on the remote? Its labelled cc. If you dont have the original Vizio remote you will need to go into menu-settings and find the closed caption and turn it off there
If pressing the cc button on the Sharp remote does not turn off the closed captioning then the closed captioning is most likely coming from the cable box or whatever you have connected to this television. You can go into the cable box menu by pressing the menu button on the front when it is turned off. That's right turn off the cable box and then press menu on it to access the hidden menu that includes closed captioning. Scroll down to closed captioning and scroll over to disable. A number of other Directv receivers have the CC located on a "captioning" tab on the "display" page under setup and for dish network: Setting Closed Captioning:
Press and release the MENU button and then select "Preferences."
U have the tv original remote.Look for a button that said CC.Pushes that CC button a few times turn off all CC1,2,3.. to all off,will not have Closed Caption anymore.Or tries go into the tv nenu look for Close Captionning or Text 1,2,3 functions tun it all to of.Will get rid of Close Captionning.
I have heard complaints from some of my customers, “There is a black/gray box on my television, but I can still see the picture around the edges”. This happens to all of us and is a common symptom and can be fixed very easily. If you have a black/grey box in the picture, on the older sets they would be perfectly centered on the screen, but, on some of the newer sets the black/grey box can be in different places and can be different sizes on different sets. Most likely the Text mode is on in the Closed Caption menu. The way you can test if it is in Closed Caption Text mode, when you change the channels, the black/ gray box will not appear right away but it will take some time to show back up. This is a very good indication that the Closed Caption “Text” mode is turned on for your television. It just needs to be turned off. To turn off the closed caption go into your menu and turn off closed caption (CC). This will vary from manufacture to manufacture; it should be in the options menu. I have seen on some sets like Mitsubishi puts it under the Video adjustments button. So you may have to look around for it. You may even have a CC button on your remote, which will make it much easier. Just press the CC button until the display indicates that CC it is off. I hope that this tip helps you and that you enjoy your televisions for years to come. Thanks for using FixYa asnowman
Captioned programs are marked in TV listings by "CC". so press the cc button on the remote and the closed caption option will be applied.press that cc button again to turn off the closed caption option. 1) Check the size and manufactured year of your television. If it was made after 1993 and is larger than 13 inches, it has a closed captioning system built into it. Otherwise, you may need to purchase a separate closed caption system, which are available at a number of online outlets.
2)Turn on your TV and access the menu for closed captioning. The precise location of the menu varies by television set. Most are accessible by pressing the "Audio" or "Set Up" menu on your remote, then scrolling down to the "CC" or "Closed Captioning" option. Check your owner's manual for precise instructions.
3)Turn the closed captioning option to the "On" position. It will then run closed captions for every program that broadcasts them. Newer sets may allow you to adjust the size, font and colors of the closed captioning letters to fit your individual tastes.
4)Tune to a particular program for a few minutes to make sure the closed captions are working. Note that while many broadcasts run closed captioning, not all of them do. If the captions don't appear, check your TV listing to ensure the program includes them.
5)If you're watching aDVdon your TV, access the DVD's "Set Up" menu. It should have captioned options, which allow you to show captions in English and possibly other languages as well.
Determine if closed captioning is available on the program that you've selected. In your program guide, the letters "CC" should appear at the end of the description. Locate the closed captioning option on your remote. Some remotes have a "CC" button that you simply need to push to activate closed captioning Locate the closed captioning option in your television's menu if there is no "CC" button on your remote. To do this, push the "menu" button on the remote control. The closed captioning option will probably be in the same section as the language function. Set the closed captioning option to "on." Within several seconds, you should see the text appear on your screen. To use closed captioning for DVDs, look for the "CC" label on the lower back section of the DVD case where it lists audio information. Turn on your TV's closed captioning and you should see the captioning like you do on a television program. Alternately, some DVDs include English subtitles that you can turn on in the setup/language menu of the DVD.
Thank you.
go into menu or setup on remote there should be an option for cc or closed caption which you can chose the language you want the normal is cc1 or turn it off... hope this helps.
This is a simple problem, somehow ypu have the closed caption on, either from the remote hit the CC or closed caption button till it says off or find the closed caption in the menu and turn it off
