Coolpix p50 camera is not recognized by computer (windows xp SP3). It does not appear in the explorer, nor as source in the 'Nikon Transfer' programm, when connected to USB port (and switched on) -> Pictures cannot be transferred. The problem occurs since the new installation of Windows XP. Before the transfer worked without problems.
Consider NOT connecting your camera to your computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Nikon Transfer or Picasa.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo cataloging program.
If you insist on using the USB connection, does Nikon Transfer recognize the camera?
I had the same problem with the same camera. What worked for my pc was to start the Nikon Transfer software, select the camera and press the "start transfer" button. Nothing happens for about 6-7 minutes, but after that the transfer starts. My pc: XP SP3 Camera: Coolpix L100 Nikon Transfer: ver. 1.3.0 (i used the software that came with the camera not the up to date version 1.5.3, but it might work with that version also
The best way to transfer pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo management program, such as Picasa. Organize edit and share your photos
