Sony VAIO® VGN-CR120E PC Notebook Logo
Posted on May 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Going to reset my computer. Where can I find the reset button?
Anonymous
Level 2:
Novelist:
  • Expert 112 Answers
  • Posted on Jun 24, 2010
Anonymous
Expert
Level 2:
Novelist:
Answers
112
Questions
0
Helped
48734
Points
252
If you're trying to restore the Computer to factory settings, then you can use the VAIO Recovery Center that is shipped with the Computer.
NOTES:
  1. Click the Start button, then click Help and Support . NOTE: If the Help and Support link is not available on the Start menu, re-enable the link in the Taskbar and Start Menu Properties window.
  2. In the Windows Help and Support window, click Backup & Recovery .
  3. Under Backup & Recovery , under VAIO Recovery Center , click Launch VAIO Recovery Center .
  4. In the VAIO Recovery Center window, under Choose a program , click to select the desired option: NOTES:
    • It is strongly recommended that recovery discs be created to help restore files if the operating system will not start. Recovery discs are bootable and can be used to perform a recovery on a properly functioning hard drive.
    • The Windows Backup and Restore option opens the Backup and Restore Center provided with the Windows Vista® operating system. This provides the ability to save information from the hard drive, such as personal data files, and restore previously backed up data.
    • Computer problems related to hardware can be diagnosed using the VAIO Hardware Diagnostics option.
    • One or more drivers or factory-installed applications may be reinstalled with the Reinstall Programs or Drivers option.
    • The entire (C:) drive can be restored to its original, factory-installed condition by selecting Restore C: Drive .
    • Choosing Restore Complete System will restore the entire (C:) drive, while removing or restoring the Recovery Drive partition. Modifying the size of the hard drive partitions is also an option with this type of recovery. This option requires you to insert Recovery DVDs created using the Create Recovery Discs option.
    • To remove all data from the hard drive, including the operating system, all programs and personal data, choose the Wipe and Erase Data option. This option is provided for the convenience of advanced users who want to install a different operating system, and who want to ensure all data has been removed from the hard drive first. All other users are strongly urged to avoid selecting this option.
HOW DO I FIND THE COMPUTER FACTORY RESET BUTTON ON REEBOK TREADMILL MODEL 14301
There is no reset button, the only thing you can do is unplug it for 10-20 minutes, if it is going to reset it will, if not you have a hard fault that must be addressed by a qualified repair person.
Need to do a factory reset on an ipad if I don't have the password (wife forgot the password to get in the ipad? Please help she is going cucku cuckuI
Push the top power button as well as the home button for five seconds release the power button still pushing the home button the unit will then come up with Apple logo and usb cabke plug into computer.. Laptop go to itunes and it will ask if you wish to reset unit
How do I factory reset my iPhone 6s Plus?
Plug the phone into your computer and load up itunes on the computer click on your phone.
Click on the button that says Restore iPhone. It make take a little while to accomplish.
Where is the computer reset button on a 2006 dodge stratus
What computer are you talking about , engine computer. It doesn't matter because there is no reset button. You need a scan tool or disconnect the negative battery cable for 5 or 10 min. Is the vehicle check engine light on , is that what's going on here ? You can try an reset the computer, but if the computer system has a problem it will come back on. An if the light is on you need to have it scanned for codes.
1helpful
Forgotten password to unlock samsung galaxy s2
Either connect it to your computer or you're going to have to reset your phone. For reseting you hold down the power button and up volume, and then select reset. Or if that doesn't work there is a little reset button when you take off the back of your phone, you will have to press it with a pen or something tiny.
1helpful
5answers
I don't remember the administrator/password to change the router
You are going to have to preform a factory reset. Doing this will erase all of your settings and disconnect all your devices.
All you need to do is press and hold the reset button for 30 seconds.
Once you do this you are going to need to reset up your linksys device. See the guide at linksys-wrt54g-wireless-router/">http://technicallyeasy.net/2007/09/securing-linksys-wrt54g-wireless-router/
Rapid depth reading variation during ascent
change the battery and use the reset button to manually reset the computer
2answers
Hiya Can you tell me where the reset button is on a HP NOtebook 6530b ?
hello there is no reset button just the power button which if needed you can hold it down for about 8 to 10 sec to make your system power down you can reset by going to reset on the windows menu
1helpful
How do i reset my gogear
there is a needle size hole in the bottom next to the hold button. You are going to have to use something small like a needle to push it. Or you can hold the up button while plugging it in the computer.
Not working
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
