Smart Drive washers do not have a belt... If you can't get power, you've most likely burnt out the motor controller board. This is probably due to another component failing...You should call a tech....To remove the water, remove the cone from the centre of the agitator, and undo the large wing nut inside the tube. This will let you remove the agitator and ladle out the water.....Good luck.....Nomess
