Question about Bunn VPS Coffee Maker
Coffee is really week
Coffee comes out really weak - have clean it out with XLR but still continues to come out very watery and weak
Posted by george486 on
Ernest R
    President:
  • 1,618 Answers
Check the sprayhead, make sure all holes are clear, then check the grind on the coffee it might be too coarse, and also check the amount of coffee being used, you need about 2 to 2.5 ozs.
Posted on May 18, 2010
My tassimo coffee comes out watery
Make sure you push the lid down all the way before putting the clamp down on the front.
I've noticed that the back of the lid on my vivy (t12) can get stuck up (even with the clamp down) causing the water jet to not be inserted all the way - which produced very weak coffee.
May 14, 2012 | Braun Tassimo Coffee Maker
My Machine Francis X6 has presented the problem of variation in the amount of water - quantity / volume of coffee in the cup when making coffee. Ouvir Ler foneticamenteDicionário - Ver...
If these rules are not heeded, then one will get anything
but a perfect espresso, because:
if the amount of ground coffee is less than 7 grams
an insufficient amount exists for extraction weak and watery
if the grain size distribution is too coarse
neither the solid nor the colloidal parts will be extracted weak and watery
if the ground coffee is not compacted
the colloidal parts will not be extracted weak and watery
if the coffee is too coarsely ground weak, watery, barely aromatic, sour, bitter
considerably less than 25% will be extracted and unpleasant, the aftertaste will not last long
if the water temperature is less than 97 Degrees Celsius
the extraction will be reduced predominantly sour
if the water does not have a minimum pressure of 9 bar
the colloidal particles will not be able to be extracted predominantly bitter
if the water temperature is much above 97 Degrees Celsius
the coffee will become scorched during the extraction bitter and woody, will smell charred
its a science and trial and error to get the right/perfect cup. due to where u live (atmospheric pressure) and temp/humidity. read this for a better understanding
http://www.coffeekid.com/files/2/xproject.pdf
Jan 14, 2011 | Husqvarna SM 510 R Motorcycles
Coffee is too weak
I just spoke to someone at customer service. My coffee has been weak and kind of thin. We had the Superautomatica by Saceo for years and I remembered the coffee being richer.
Anyway! The person suggested that I adjust the grind but slowly. So set it to the coarsest setting, brew 2-3 cups. Then put it to the 2nd-coarsest setting, brew 2-3 cups. To the third, brew 2-3 cups. To the forth, brew 2-3 cups. Etc. Until you're at the finest grind setting. Again, brew 2-3 cups. An awfully sensitive machine. It seems to have worked although the last few seconds of brewing continue to be a kind of milky colour (as opposed to a deep black coffee colour). You can, though, press the "cup" button to stop the brew. So once, it starts running milky, you can stop the cycle.
I hope this helps. I know I've been struggling and cursing the machine for a while :)
Dec 30, 2009 | Saeco Odea Giro Plus Coffee Maker
How can I ajust my machine the coffee is coming out weak and watery I don't get that creamy,strong coffee anymore
HI
There are more than a few things that can cause weak coffee.
Grind is too coarse. It should look like coarse sugar.
You cleaned the brew unit and left a part out or put it in incorrectly.
Grind adjustment is set too high. Turn to a lower # while the grinder is operating.
Grinder is been taken apart and not put back together correctly.
Grinder is broken and the grinds are just big chunks.
Oct 23, 2009 | Spidem Trevi Digital Coffee Maker,...
Shots too watery
1, Check the grind on the grinder. Imagine grounds as rocks and sand, if you are using rocks then the water will run too fast and with sand it will run too slow.
2, If using an automatic machine(water volumes are pre-measured), check to make sure that you are getting the correct volume(3ozs fro a 2ozs shot, and 4ozs for a 3ozs shot), an once of water stays in the coffee during extraction.
3, Adjust the tamp(packing pressure) of the coffee, fill the portafilter with coffee a little over the top, then level it out and tamp to the fill ring on the inside of the basket.
Jun 03, 2009 | Wega Mininova EPU Espresso Machine
Coffee out of the machine seems too watery
Basing on personal experience (you can find more on Google probably), solutions are:
On percolated (filter) coffee machines:
Check water temp, if water temp is insufficient , most common is scale heating element , faulty element, faulty thermostat.
Check if water is dripping right at the center of the filter, if it is dripping on one side because the orifice is clogged, that can result in weak coffee.
Coffee blend not well distributed on filter basket.
On Espresso machines:
Check water temp, same as filter coffee machines (thermostat element, scale on heating chamber).
Ensure that coffee is filled correctly in the filter cup (fill at level), and well pressed.
Ensure that the coffee mixture that you are using is not too coarse, buy the apposite one for espresso.
Ensure that you are not leaving the machine brewing for a time that is too long, and Italian coffee cup is very small, approximately one regular shot.
On the hob moka pots (espresso, Moka and Bialetti type):
This are the trickiest ones, you need art and practice to get a good espresso with a Moka, but when you learn, the result is better than what you may get with an home electrical espresso maker.
The frame on the hob must be not too strong, and the mixture coarse but well pressed, with water at level tag, or you will get a weak coffee.
On Mokas a good strategy is keeping hob at minimum, and turning up the flame at top when coffee starts coming out.
French and turkish cafetieres:
Ensure that you put enough coffee, water hot enough, and that you left the infusion enough time to get a strong coffee.
Note: insufficient pressure and clogged lines on electric machines never give you a weak coffee, exactly the opposite.
Not pressed mixture always gives weak coffee, but too much pressed mixture may give you coffee with bad taste.
Feb 22, 2009 | Gaggia Syncrony Compact Coffee...
Coffee is weak and watery
After reviewing troubleshooting diagrams, I really couldn't find a solution to your problem.
The only thing I can suggest is to use 2 oz per pot of coffee grounds. Your 5 or 6 scoops assuming they are one ounce each is way more than enough.
Look under where your basket goes. Most bunn coffee maker has a flavor guard on the downspout. this down spout actually helps distributes the water over the whole basket of coffee grounds. Most of the time I see these missing, and when they are gone, they are gone.
Use less water for the amount of coffee you are using first. Sadly when there is not enough water, the coffee tastes bitter. Too much water tastes weak. Hot water extracts certain elements out of the beans even after grinding.
Always use a fresh paperfilter designed for your coffee maker.
If this pot is not work correctly still, I will suggest seeing your appliance repair technician.
May 26, 2008 | Bunn BT10B Coffee Maker
Watery tasting coffee
Have you tried cleaning it with the 64 ounces of white vinegar?
Read your booklet if you still have it. Pour the vinegar in run it through until it ask for more water to be added and just let it sit overnight or at least 8 hours. Then flush it out with fresh water at least two or three of your water tanks should do it. Then give it a try again.
Just a suggestion if you haven't tried that yet. Hope it helps.
Dec 02, 2007 | Keurig B70 Coffee Maker
Bunn VPS Coffee Maker Logo
158 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
gbob59
Marvin
Marvin
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
