Question about iSonic SNAPBOX AV80 Camcorder
I need a replacement Battery for a snapbox AV80 8 megapixel The LI-ION 3.7V 850mAH (Product Standard) GB/T18287-2000 S/N:6D11002639 What is this compatable with Eg. Cannon, samsung, kodak ? I need a new battery my last only 20 minutes after a few years.
    New Friend:
    New Friend:
  • 61 Answers
Look on ebay
Posted on May 19, 2010
My RST501 Radian cordless handset needs a new battery but I can not find, pls advise where I can get one. Thx Peter
This is a standard typical cell phone battery, 3.7V lithium ion. But the size is really small indeed. Its a really tough one to find, and you'll probably have to source it from some battery wholesale overseas or use something like item number 181401026180 from eBay seller onlineorder2013 and then retrofit it to the factory leads and connector. Maybe an old dead bluetooth headset would give you a decent battery to substitute. Just an trick old technicians would resort to when parts are not available to fix a product. Good luck.
Jul 02, 2012 | Radian Technologies SkyTone RST501 IP...
PUK code for nokia 1.3 megapixels black and pink
PUK code can be obtained by calling the customer care of your network provider. It is an 8 digit code, just put it and phone will unlock.
May 28, 2012 | Nokia BL-4S Li-Ion Standard Battery for...
I am looking for a battery Versatis 2900 Li-ion 3,7V 720mAh Alcatel phone
You maybe able to get one on the Internet or your local phone shop.
Mar 07, 2012 | Cameras
Details of acer extensa 4620 laptop
Here's a link to the manual. All the details you could ever need.
http://www.marriage-4u.com/files/notebooks/ex_4620_4620z_4220_user_guide_eng.pdf
Jan 14, 2010 | Acer Extensa 4620 Notebook
Logitech MX1000 Laser Cordless Mouse, I replaced the li-ion battery with a NiMh AAA battery pack, soldered in the board that was on the old battery and used it for a week before the battery pack needed...
Li-Ion battery and NiMh battery have completely different charging requirements! Li-Ion battery has much stricter charging requirement and the regulator is normally design to trickle charge at 0.1 Current rating @ 4.2V and then completely shut down.
WARNING: if you use a Ni-Mh charger on a Li-Ion battery, then it will erupt and even explode and catch fire!
Bottom line is that the rescued Li-ion regulator is not designed for your Ni-Mh pack and you will never get a full charge with it and you will need a completely different regulator board: you are better off putting in a suitably sized Li-Ion battery with inbuilt regulator but with higher current rating if possible.
Hope it helps! Let me know how you go.
Nov 14, 2009 | Logitech MX1000 Laser Cordless...
Battery dead
Li Ion 3,7v 700mAhp/n 3104 200 5223.3
Apr 27, 2008 | Philips HDD070 MP3 Player
iSonic SNAPBOX AV80 Camcorder Logo
323 people viewed this question
Top iSonic Video Cameras Experts
Al Rush
Ekse
Marvin
Marvin
Are you an iSonic Video Camera Expert? Answer questions, earn points and help others
