Question about Kenmore 53092 / 53094 Side by Side Refrigerator
Door seal between fridge & freezer is hot is this normal ?
Ddor seal is hot between fridge and freezer is this normal?
Posted by courtneyduty on
Jeremy Reddick
    President:
  • 1,902 Answers
No, there is a heater in the seal of the doors to keep the doors from icing up, if it is hot to the touch then the heaters are going bad and must be replaced. You can replace it yourself by removing the door seals, and then removing the heating element that runs the whole door. When you do this make sure that the unit is unplugged.
Posted on May 17, 2010
My Samsung French Door, Bottom Freezer Model RFG297AARS was leaking into the refrigerator & pooling under the deli drawer.
Freezer /fridge water/ice in fridge and or freezer
Usually due to CONDENSATION due to bad door seals or a plugged evaporator drain line? Can use a soft flexable tubing and very hot water to clean it out. Bad door seals usually need replacement, but u can use a blow dryer and something to pry it closer to the door wall while blowing hot air on to it. To create a seal, to test for bad door seals place a dollar bill in between the door and wall of fridge where it closes. Then slide out the dollar bill with door closed. It should offer some resistance and not be easy to pull out.
Most all fridges have a drain. Look inside your fridge for a "V" shaped channel with a small hole. This hole leads to a tube and a small pan which sits on top of your refrigerator's compressor. The defrost cycle causes water to run into the channel, down the tube, and then it generally evaporates with the heat of the hot condenser/compressor.
However, if that tube is clogged with food crumbs, particles , debris etc, you will have to clear it to get back to a normal mode of operation. A toothpick, pipecleaner, straw or a cotton bud can often do the trick.
Even a frost free freezer will still ice up at times in the areas away from the heated defrost area and the drain line can freeze. This icing causes the pipe work to the compressor to ice over or sweat and cause a puddle. Or if the drainage has frozen over, it will need to be de-iced. ( usually the line is under the freezer bottom plate covering. Towards the back of the unit) And there is another inside the fridge area also.
Give the freezer a good overnight defrost until it's totally clear of ice in addition to making sure the drain is clear to the pan at the back and then restart the freezer.
Apr 05, 2015 | Samsung RFG297AARS Bottom Freezer French...
I have a Samsung french door fridge.
Apr 02, 2015 | Samsung RFG297AAWP Side by Side Bottom...
I have an artic king freezer model arco7mw and it has puddles of waterneath,why is that?
Mar 02, 2015 | Refrigerators
I have a samsung refrigirator side by side with a bottom freezer door. It is leaking from the bottom of the right side of the freezer right of the free
Jul 15, 2014 | Samsung Refrigerators
Freezing around door of freezer
Jun 01, 2014 | Samsung Refrigerators
My Fridge where the doors close is hot to the touch. This is a new problem that prior to today did not occur. I bought a new fridge and put the old one in the garage. It is plugged into a dedicated...
The hot temperature that occurs in the fridge body is normal and you have nothing to worry. It is the result of the heat pumps during a normal operation. Once the fridges reaches the normal temperature it will automatically shuts off and the hotness of the body will disappear.
Dec 01, 2010 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Front metal , top heating element very hot
This should be OK. There are heat strips placed behind the door frame to prevent sweating around the door frame due to the metal being cold normally without the strips. Thanks, Sea Breeze
Jul 21, 2009 | Refrigerators
Outer portion of divide between freeze & fridge where door seals rest when doors are closed very hot
This normal. The heat you feel is very important in keeping the influx of warm from infiltrating the refrigerator. The barrier ensures that you will not experience any frost or icicles in you freezer.
Jul 01, 2009 | Refrigerators
Outside freezer hot and seals
Fridge has either mullion heaters around door or most likely steel pipes just inside the skin of the perimeter of the door, this is to stop ice or condensation forming around the door seals, mainly the freezer, they are part of the condenser circuit ( hot part of the refrigeration system).
It is normal for these to get hot, but in your case may be hotter than usual because of the constant running, the running may be caused by hot ambient temperatures, system being slightly short of refrigerant, faulty thermostat or in-efficient compressor.
I suggest if temp is ok inside fridge dont worry too much, if you notice fridge starts loosing its capacity to refrigerate, have a refrigeration tech look at it.
Nov 13, 2008 | Maytag MSD2756G Side by Side Refrigerator
Seals are hot
hI iF YOUR FRIDGE AND FREEZER ARE COLD AND TEMP IS OK THEN ITS FINE oN FRIDGES THERESHEATERS THATGO AROUND THE DOOR TO KEEP THE CABINET WARM TO STOP CONDENTION SO THIS IS NORMAL THANKS FOR THE QUESTION THE APPLIANCE DOC
Sep 12, 2008 | Sub-Zero 632 / S
Kenmore 53092 / 53094 Side by Side Refrigerator Logo
1,436 people viewed this question
Top Kenmore Refrigerators Experts
gbob59
Dale Copeland
Dale Copeland
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
