Question about Panasonic NV-DS60 Mini DV Digital Camcorder
Panasonic nv-ds60 the door will not close for the tape and it keeps making a clicking sound when i switch it on
Posted by irisrun on
Anonymous
    New Friend:
  • 61 Answers
Tape in backwards
Posted on May 19, 2010
MY PANASONIC CAM RECORDER STOPPED WORKING BECAUSE
The tape will be badly damaged if trapped in camera, this always happens when the camera has got dirty heads and capstan rollers, some times the door wont open if this happens, but if it does open your local camera shop may get the film out.
Jun 16, 2010 | Panasonic NV-DS60 Mini DV Digital...
Dew symbol on panasonic NV-DS60
My panasonic camera does the same- from what research I've done online the only method (that REALLY works) is removing the battery pack and hitting the camera (where the battery was at, don't hit it too hard) with the palm of your hand. I didn't believe this until I tried and *poof* it worked back normal.
Nov 13, 2008 | Panasonic NV-DS60 Mini DV Digital...
Help for Panasonic NV-DS60 video camera
J4AI EU UN PROBLEMES AVEC MA CAMERAS PANASONIC NV-DS60,QUI CLIGNOTE SENT A RAI.ET QUI NE MARCHE PAS
Jul 04, 2008 | Video Cameras
Connecting my nv-ds60 to my computer
plisss send my draiver camera video panasonic NV-DS60
May 06, 2008 | Microsoft Windows XP Home Edition
Panasonic Mini DV NV-GS11EG "push the reset button"
i know what to do next brother go to field or a soccer field and trow the bloddy thing away
Mar 25, 2008 | Panasonic NV-DS60 Mini DV Digital...
Panasonic nv-ds60
The fix is really easy and costs nothing, just 10 minutes of your time!
*I fixed mine (twice) this way*
Turn the cam over.
remove all the screws holding the dark plastic bottom on the camcorder, remove it carefully.
Now you will see the ribbon cables, VERY GENTLY, wiggle them from left to right (about 1mm each way), then push them in.
Test by putting your battery back on and see if it holds a tape, or plays without blinking and switching off - you will be happy.
The fault is simply that one cable (I can't tell you which one) becomes loose over time, so it just needs to be pushed back in and the condensation error and/or the door closing problem go away!
A lot of folks are buying cams off eBay like this as it's such a simple repair!
Good luck - please help others - post back if it works!
Dec 03, 2006 | Panasonic NV-DS60 Mini DV Digital...
Panasonic NV-DS60 Mini DV Digital Camcorder Logo
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
