Question about Hayward 250kbtu Ng Pool Heater - Inground
Spa heater will not ignite. Shows "AO" code.
Spa heater installed last winter. Bought it from Leslie's and let their installer put it in. Most times it acts like it is going to ignite, then it shows a code "AO" and shuts down. I beleive it has something to do with the blower switch.
Any ideas?
Posted by paul_brig337 on
Anonymous
    New Friend:
  • 64 Answers
AO usually has to do with the blower vacuum switch. Several items can cause an AO fault code. First thing to check would be is the blower on? If it isn't, then you would need to check to see if the blower is getting the proper voltage. Proper voltage depends on the exact model of heater. If the blower is on, then you will need to check the blower vacuum switch. You will also need to check the tubing connecting the blower vacuum switch to the blower. Any breaks or a disconnected tube can cause this error. Also, it could just be that the vacuum switch is faulty.
HTH
Posted on May 20, 2010
Kieran Ruppert
  • 990 Answers
You need to check and see if you have enough gas supply to run the heater. Older heaters would run on a small gas supply but forced draft are hinkey about how much gas they get. Sometimes this is a gas line size problem but more often than not it will be a gas meter problem. On the face plate of your meter their is a number that tells the size. With a 250 and other appliences in the house you will want a 350 or bigger. The good news is the gas company will upsize this for nothing. If they are supplying more gas your buying more gas. It could be other things but this is the first thing to look into.
Posted on May 17, 2010
Brand new just installed with gas hooked up ao error message tube okay and blower working - ao message after about 1 minute after turning on
I recommendyou call the Hayward technical support at 908-355-7995and they might be able to help you figure this issue out. Ihope this helps.
Sep 17, 2011 | Hayward H Series Pool & Spa Heater 400k...
Ao error message in Hayward heaters
You didn't indicate exatctly which model you have. But on most the AO error code is :Blower vacuum switch
open error If the blower prover switch does not close after the blower starts the control will
stop the ignition trial go into lockout. The blower will continue to run. Automatic reset is immediate after the switch closes.Check to be sure combustion blower starts
If you don't have your manual you can download one for your exact model at : www.haywardnet.com
Jul 29, 2010 | Hayward H Series Pool & Spa Heater 400k...
Expected life time of Sta-Rite heater?
Thank you for posting your question here on Fixya.com.
Overall heater life is often dictated more by the pool maintenance history and chemical usage than location. Generally speaking up here in the Midwest you can expect 12 - 15 years of service life from a heater. More if it gets pampered with such treatment as proper winter covering and regular cleaning and maintenance. Far less if chemical issues arise in a pool and are not dealt with properly. A heater can fail in a matter of weeks if water conditions are that poor.
So, to answer your question; with proper installation, maintenance and water treatment I’d put it at 15 – 18 years before the heater will have spent itself from wear.
If this answer does not fix your problem or you are not sure about part or all of this post, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Mar 23, 2010 | Sta Rite Sr333na Max E Therm Pool & Spa...
I had code AO displayed on my hayward H250IDE. I
Check your wiring again on all the safety devices - Water pressure switch and both Hi- limits in the header.
Feb 19, 2010 | Hayward H Series Pool & Spa Heater 400k...
Blower runs but no ignition then AO error code
Your problem then would be the pick up tubing and/or switch attached to the blower that closes once the blower is on to allow the heater to ignite. Pull the tubing and check it for dust or other debris clogging it and check inside the blower housing for the same. If you can test the switch under operation, you should see it remains open during start up which is why the burners won’t fire. If you do not find any obstruction (if you can, blow some compressed air thru too just to be sure) then you will need to replace the switch.
Jan 04, 2010 | Hayward H Series Pool & Spa Heater 400k...
My pool and spa heater is not working diplays service codes bo and AO
MAKE SURE THE FILTER IS CLEAN THAN THE TEMPETURE SENSOR MAY BE BAD, CLEAN THE FILTER FIRST
Oct 10, 2009 | Hayward H Series Pool & Spa Heater 400k...
AO error
This error is produced when the blower prover switch does not close after the blower starts, the control will stop the ignition and go into lockout. Automatic reset is immediate after the blower prover switch closes.
If you keep having this problem, contact a reputable service company, especially if it's under warranty.
The link to the owners manual is below, it references fault codes, etc..
Hope this helps.
http://74.125.95.132/search?q=cache:4mAdY7bLfoQJ:www.haywardnet.com/products/Manuals/pdfs/Manual227.pdf+hayward+AO+error&cd=7&hl=en&ct=clnk&gl=us
Sep 16, 2009 | Hayward H Series Pool & Spa Heater 400k...
Pool heater will not ignite
My heater worked ok , btu made a clicking sound, now it shows a AO error? What can I do I dont have enough money to call a pool man again.
Jul 03, 2009 | Hayward H Series Pool & Spa Heater 400k...
Hayward 250kbtu Ng Pool Heater - Inground Logo
482 people viewed this question
Top Hayward Pool & Spa Experts
john h
Marvin
Marvin
Paul Carew
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
