Hello!
Please can you help me? I have a Dell laptop and it has suddenly stopped working. When I turn it on a black dos screen appears telling me I need to reinstall the windows disk and click repair. My first few attempts of this did not work so I tried to diagnose the problem by running a test. (I pressed F12 on the blue dell screen) An error was detected with the code 0142, there was also another code 2000-0142, status 70.
Eventually I managed to gain a response from the windows disk but it was extremely slow so stopped it as I didn't want to brake it any more.
I understand there is a problem with my hard drive but I am no longer under warranty and cannot afford a new laptop or to call out Dell. Please can you advice me if I can purchase a new hard drive and which one should be compatible? Also if i will be able to extract any of the files from the broken hard drive?
I think its the Inspiron 1750 but not sure.
Thanks
christianne
It sounds like you drive has bad sectors. You can replace it with any 40-250GB ATA 2.5 inch drive. If you want your data back, you can still ready you data with tools like ddrescue and create an image file. Then you read the image file with a file carving utility like photorec. It's not quite that easy, since those are command line tool, but your geeky friend will help you with this. If you want somebody else to do it for you there is Data Recovery NYC. Also there is good information on hddguru.com.
