Question about Toymax Viore 42 in. Plasma TV
Need Viore code for ATT-U-Verse remote.
Can't get remote to operate TV. Tried all codes given by Viore and AT&T.
Posted by shakeyz59 on
Anonymous
    New Friend:
I tried every code suggested for my Viore with Uverse and nothing worked. Finally decided to reset the remote to factory settings using code 900 as described in the instructions from ATT uverse. The remote now works on my Viore tv and all I did was reset the remote to factory settings.
Posted on Feb 05, 2011
  • Anonymous Oct 12, 2011
    Have 2010 32" viore tv.Could not find att code for uverse remote.Discovered samsung code 1482 will work just fine.Go to help menu on uverse remote find tv set up.Choose your remote(mines was the silver one)go samsung enter 1482 ck volume then to see if it took.This should work 1012/11
Anonymous
Viore will work on samsung code 1482 (dated 10/12/11)
Posted on Oct 12, 2011
    if samsung code 1482 did not work it will be in that range 148_ 1484
Codes for Seiko tv
Remote Control Codes For SEIKI TVs
  • DIRECTV = 10178 11687, 10178, 10835, 10056, 10150, 10463, 10156, 11498, 11401, 0178,
  • Comcast = 11864, 10178, 0060.
  • Cox Communications = 0178.
  • Atlas DVR Device URC = 0178.
  • Time Warner Cable = 0178.
  • Philips = 0002.
  • Bell Remotes & Dish Network = 505, 506, 516, 523, 526, 566, 573, 612, 627, 647.
  • ATT U-verse = 1004.
https://codesforuniversalremotes.com/remote-control-codes-for-seiki-tvs
Trying to sync my ATT u-verse remote to TV, need code.
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
PROGRAM MY UVERSE REMOTE TO TCL TV
0174,0179,0173,1070. Try these codes. If you wish to get more, try the following links. Both the sites linked have set-up code list & set-up procedure to many popular brand remote controls.
2helpful
2answers
Att u-verse remote code for coby tftv1923? not
Here, try this link. It's a rather large pdf, so it may take a little while to open.
https://uma.att.com/assets/files/U-verse_Feature_Guide.pdf
Att uverse remote won't work with other devices
Yes you have to use the recommended Uverse codes, and follow the directions to enter the code. Hold the tv button down, on the Uverse remote, then with it stil held down add the OK button, let go of both, then you will see the lights at the top of Uverse remote light up, it is then ready to accept the code, it will be a four digit code, Go to [email protected], and look under TV, then programming the remote is there. Put remote Code in the att search box if you can't find it.
6helpful
2answers
75helpful
4answers
2helpful
2answers
Need remote control code for ATT U-verse
Use the code search method. MANY TV's are branded from a few suppliers. Emerson has about 50 codes!
Toymax Viore  42 in. Plasma TV Logo
Top Toymax Televison & Video Experts
Ekse
Tom Chichester
Are you a Toymax Televison and Video Expert? Answer questions, earn points and help others
