Question about Intuit QuickBooks Pro 2008: Windows
Error 1334/ quickbooks pro 2008 - Intuit QuickBooks Pro 2008: Windows
Posted by joncymanila on
  • Akshay M
    Akshay M Jun 30, 2020
    Steps for Resolve QuickBooks Error 1334
    Solution 1: If you get the error while launching or opening QuickBooks:
    In order to solve this error, you need to Find and open your QuickBooks company file.
    QuickBooks company file. has the file extension .qbw.
    You have to Double-click the company.qbw file.
    Solution 2: Clean installation of windows:
    In this step, try to resolve your Error 1334 issue. Reinstalling Windows will erase all the data from your hard drive, allowing you to start again with a new system. Furthermore, a clean install of Windows will also immediately clean out any and all junk that has accumulated over the normal usage of your desktop.
    solution 3: Advanced Solution:
    Start the computer, and then log in as an administrator.
    You need to select Accessories and Programs, System Tools, then select Restore.
    select Restore my PC with an earlier date, In the new window, and then click on Next.
    select a restoration point list, and after that click Next.
    Then click, Choose the latest system restore date inside the in the verification screen.
    when the repairment is ended, Restart your desktop
    Ideally, the above-talked about answer for QuickBooks Pro Error 1334 will help in resolving the error.
    Learn more about
    QuickBooks Hosting Services
    QuickBooks Enterprise Pricing
    QuickBooks for Mac Desktop
  • Anonymous Jun 30, 2020
    spam sux.
Hp Printer Support Assistant
    Novelist:
    Habit-Forming:
  • 76 Answers
QuickBooks application is intended and intended to increase mid-and small-sized industries ' productivity. The program comprises of multiple functionalities that allow a user to accurately manage accounting and finance. QuickBooks also suffers from some mistakes, similar to other apps. QuickBooks Error Code 6130 is one of the technical mistakes prevalent in QuickBooks. QuickBooks error code 6130 appears when there is no backup, only temporary files, in your business records.
https://www.quickbook-support.com/quickbooks-error-code-6130/
Posted on Sep 05, 2019
jon markan
    Habit-Forming:
  • Intuit Expert
  • 256 Answers
Find and open your QuickBooks company file. It has the file extension .qbw.
Solution 2: If you get the error when updating or repairing QuickBooks
Please see Error: 1334 while repairing or updating QuickBooks for steps to resolve.
Solution 3: If you get the error when installing QuickBooks
Please see Repair or reinstall Microsoft .NET Framework for steps to resolve.
for more help visit
QuickBooks Technical Support
Posted on Aug 22, 2014
4 Related Answers
Anonymous
SOURCE: Quickbooks Pro-restoring a back up from a previous version 2005
If is any help - we have just had the same problem.......had version 5 (very old) of QB
changed computer to Vista and would not work so had to buy Pro 208 for Vista . We really had to get in touch with Quickbooks - they send you a free upgrade kit (disc which is Pro 2006 version (not a fuull version but enogh to get the data over) then you load that on your old machine transfer your data to that then copy that again - then load into Pro 2008 - worked fine for us - have come across a hiccup with VAT - but however I guess we are going to have to give in and phone them after the Bank holiday........apart from that everything was fine.
be brave and phone 'em - tech support was helpful.
Posted on May 24, 2008
Anonymous
  • 32 Answers
SOURCE: went to open Quickbooks pro
Update your Quickbooks, run reboot.bat, restart your computer and then restart Quickbooks
  1. Open the folder containing the reboot.bat file:
  2. Windows Vista: Right-click the QuickBooks icon on your desktop and select Open file location.
  • Window XP:
    1. Right-click the QuickBooks icon on your desktop and select Properties.
    2. Click Find Target.
  1. Double-click the reboot.bat file
Posted on Feb 06, 2009
Anonymous
  • 32 Answers
SOURCE: Quickbooks Pro 2008 Payroll Setup
Did you set up the simple plan through the ez set up? QuickBooks will automatically default to the USUAL settings -ie employee portion is only taxable at the state and local level)
You might want to check how you have it set up. To do this
Go into the edit payroll item, click through until you find the screen for Taxes and select the items that are affected by the contribution (check with your state and local taxing authorities to see if you need to withhold for the employee portion)
Posted on Feb 19, 2009
Anonymous
  • 1752 Answers
SOURCE: Quickbook pro 2008 slow to respond
Install it on a newer PC.
Posted on Oct 23, 2009
Error code (-6000,-83)
1.. Your solution depends on what action you were taking when the error occurred. Please choose the appropriate selection.
You are opening your company file
You are storing your company file on a Windows server
You are storing your company file on a Linux server
You are restoring your company file
2.. Intuit recommends more than one solution for this problem. The first solution may solve your problem, or you may need to try all of them to resolve the issue. For best results, perform the solutions in the order shown.
Solution 1: Change the extension if the restored file extension is .qbm or .qbw.adr instead of .qbw
Solution 2: Check for problems in your file name and file path
3.. You are creating a back up
Create a new File Folder on the root of the C drive.
Create a backup and save it to the newly created File Folder.
for more help visit
QuickBooks Tech Support
Feb 12, 2013 | Intuit QuickBooks Pro 2008: Windows
Tip
Quickbooks Download Websites
IF you are using Intuit Quickbooks, Here's the download Websites:
Quickbooks Pro 2008 : Download
Quickbooks Premier 2008 : Download
Quickbooks Pro 2009 : Download
Quickbooks Premier 2009 : Download
Quickbooks Pro 2010 : Download
Quickbooks Premier 2010 : Download
Quickbooks Pro 2011 : Download
Quickbooks Premier 2011 : Download
Please make sure you know your License Numbers
Please rate if this helps..
Thanks!
on Mar 16, 2011 | Intuit QuickBooks: Pro 2005 for PC
Error code 3371 status code 0 QuickBooks SimpleStart 2008
http://support.quickbooks.intuit.com/support/articles/sln40318
Aug 02, 2011 | Intuit QuickBooks Pro 2008: Windows
Quikboos pro 2008 fails to load. It is on my
Is there any error message? Try to launch your QuickBooks by holding the CTRL key until it fully load. If it's still the same, try to repair your QuickBooks.
Jan 11, 2010 | Intuit QuickBooks Pro 2008: Windows
I have been getting error code -6000; -83. What
Might I suggest going to the Getsatisfaction website. I have provided a link that will direct you there.
http://bit.ly/7ebRo
You can use OpenID, Windows Live/Bing, or create a new username.
Hope they can help you out.
Jun 05, 2009 | Intuit QuickBooks Pro 2007 Full Version...
Went to open Quickbooks pro 2008 and received an error code of 80029c4a. It also said there was an error loading type library/DLL. Any solutions? Thanks
  • Window XP:
Jan 06, 2009 | Intuit QuickBooks Pro 2008: Windows
May 05, 2008 | Intuit QuickBooks Pro 2008: Windows
Intuit QuickBooks Pro 2008: Windows Logo
480 people viewed this question
Top Intuit Computers & Internet Experts
Ekse
Mike
SANTHOSH
Are you an Intuit Computer and Internet Expert? Answer questions, earn points and help others
