Question about iLO LCT32HA36 Television
Ilo LCT32HA32 tv wont turn on, no red standby light
I have an ilo tv model number LCT32HA36. The tv will not turn on the red power button blinks and won't turn green when the power button is pressed. Now when I plug the tv into the wall the red standby light does not light up. Does this mean that the power supply is shot? Could it be fixed by replacing the bad caps?
Larry
  • iLO Master
  • 2,812 Answers
It could be the power or main board that is giving issues...if your able pull the back off and look for a pin on connector marked PSON or PON...that is line that tells the power board to come out of sleeping and go to work, you should see a change in the voltage when the on button is pushed, if you do then the main is doing its work and its the main if you don't see a voltage change then chances are its the power board
Posted on Dec 14, 2017
5 Related Answers
Jaime Hernandez
  • 2337 Answers
SOURCE: iLo tv
It looks like the power supply failed on your TV. If the LED is solid red or green, it could be some leaky or dry capacitors but if the LED is blinking, the failure is more complicated to repair.
I service these power supplies. If you need more info you can send me an email to [email protected]
Posted on Jun 04, 2008
Anonymous
SOURCE: Ilo LCT32HA36
http://www.newremotecontrol.com/Mfrs/OtherBrands/Def/dyn_part_data.php?catnum=E7501-056104
Only possible solution!
Posted on Nov 25, 2008
Anonymous
SOURCE: LCT32HA36 Power Supply went up smoke.
You can probably fix it yourself. If your board failed the same way mine and seemingly almost everyone else did, its actually a very simple fix.
Up where all the cables plug into the board are 3 capacitors, running perpendicular to the inputs. They are the 3 BETWEEN the two black heat sinks. Those 3 have a habit of over heating and going bad. its easy to tell... the tops should be slightly bulging outward and you may even see specs of brown on top. If that's the case, you've got it easy. Go to Radio Shack and buy 3, 35v 1000uF capacitors, item # 272-1032. They're $1.59 ea. Use a soldering iron to take out the old capacitors, fit the new ones in, and replace the board into the TV. The new ones are a bit larger, but fit just fine. I suggest setting all 3 in BEFORE soldering them in, just so you can be sure they are in good position.
I bought all three capacitors, solder, and an iron kit for $35, about $150 cheaper than a new board. Its a 10min job and well worth the effort.
Posted on Jan 08, 2009
Jaime Hernandez
  • 2337 Answers
SOURCE: No Power
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to [email protected] if you require further assistance
Posted on Feb 21, 2009
Anonymous
  • 10 Answers
SOURCE: have ilo lct32ha36 and powers on and hear sound,
you have a bad master and slave inverter board these are the skinny boards that go verical on the back of the unit
take you unit apart remove back and look at the back of the tv face down on a blanket remove all the screens take the back off remove those two board going vertical look up both parts on google or call or go to shopjimmys.com
Posted on Oct 19, 2009
Will not power on led flashing red and now no led
Reset your TV. Unplug your iLO TV from the wall and remove any connected devices. Hold the front power button in for five seconds, then release. Plug your TV back in, turn it on and confirm that it is working again.
Read more: http://www.ehow.com/how_5458819_troubleshoot-ilo-tv.html#ixzz2tRuiKHvE
Jan 21, 2014 | iLO LCT32HA36 Television
I cant get sony trinitron to turn on. the standby/timer red light blinks several times and it wont turn on what can i do i am bored without tv
Likely damage to main power supply-------try to see if there is a specific number of blinks then a pause and repeats like 7 blinks a pause and repeats---that is an error code if there---with it AND THE MODEL NUMBER OF THE TV I might be able or not to help.
May 25, 2012 | Televison & Video
I found a ilo 32 hdmi t.v. model lct32ha36, there is not a button that says on/off. Just a standby. I want to figure out if it works before I by a remote to test it. Can you suggest anything?
Most new televisions are actually labeling the "power" button correctly. Unless a tv is unplugged, it is never really off. It just goes into a state of standby. This is what you would have called your power button.
Jan 03, 2012 | iLO Televison & Video
Our iLo LCT32HA36 will not power on. The light will blink red and then stay red..
It may be in the safety shutdown mode due to power supply problem or failed backlight inverter boards.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Please post back what you find.
Oct 21, 2010 | iLO LCT32HA36 Television
No Power
It's possible your TV when into protection mode. This happens when a part is burned out inside your TV to prevent further damage.
Try unplugging your TV for 30mins. Then see if the problem still occurs.
If the problem is still there, you may have to take it to a repair shop to diagnose the problem.
Feb 09, 2009 | iLO LCT32HA36 Television
ILO 2600 SILO LCD COLOR TV
sounds like the power supply
Oct 12, 2008 | iLO LCT32HA36 Television
TV wont' turn on
The failure on your LCD is due to a defective power supply. Leaky or dry capacitors is the reason for the failure. Replacing or repairing the power supply should fix your LCD.
Contact this website and ask them if they have any power supplies in stock.
Good Luck.
Sep 04, 2008 | iLO LCT32HA36 Television
ILo tv
Jun 04, 2008 | iLO LCT32HA36 Television
Ilo 27" lcd tv
If your LCD has a defective power supply module will cause the following symptoms:
No Display and no Sound, Then Power indicate light changes from Green to Red.
Apr 29, 2008 | iLO LCT32HA36 Television
iLO LCT32HA36 Television Logo
219 people viewed this question
Top iLO Televison & Video Experts
Lee Hodgson
Lee Hodgson
CoppellTVRepair.com
matt martin
matt martin
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
