Question about RIM BlackBerry Storm 9530 Smartphone
How do i solve the jvm error 102 on my blackberry storm
  • 846 Answers
Your Blackberry probably just needs a firmware restore. Here's a guide on how to restore the blackberry firmware, the website is at : Restore Blackberry 9530.
Posted on Jul 10, 2010
biz2348
CommCentral
  • 237 Answers
SOURCE: how do i solve the jvm error 102 on my blackberry
you need to reload your phone's software.
files can be found at blackberry.com
Posted on Mar 29, 2010
Hi I haven't used my phone for a couple of years. when I switch it on now it say.. error 102 reload software... what do I do?
You need to do a Factory Reset, AKA a Hard Reset. This removes everything on the phone and reloads the operating system. Your phone is a Blackberry?
  • Error 102 Reload Software - BlackBerry Support Community ... https://supportforums.blackberry.com/t5/BlackBerry-Device-software/... Hello, I've just had a problem with my Blackberry 9930 phone. I already tried updating the Blackberry Desktop Software and I also tried the phone,
  • Error 102 - Reload Software - Blackberry Torch 981 ... https://supportforums.blackberry.com/t5/BlackBerry-OS-Smartphones/... Hi. I took the battery out of my phone and when the phone re-booted I now can only see a white screen with the error 102 and states reload software.
  • How to Reload Blackberry Mobile Software - Snapguide snapguide.com > Technology > Explore
    • 3.5/5
    • 10 RATINGS
    • BY TAHANI ALGHAREEB
    i will teach you how to reload your blackberry soft ware when its got error 102 and not working by this steps. all you ... How to Reload Blackberry Mobile Software
  • JVM Error 102 on your BlackBerry? Try this solution BEFORE ... crackberry.com > ... > Classic > Z30 > Z10 > Q10 > Leap > OS 10.3.2 Video embedded · JVM Error 102 on your BlackBerry? Try this solution ... JVM Error 102 on your BlackBerry? Try this solution BEFORE wiping! ... "Error 102. Reload Software ...
  • Terpecahkan: Curve 9360 Error 102 (Reload software ... forumdukungan.blackberry.com/...Error-102-Reload-software/td-p/258111 Terpecahkan: Dear all, Saya newbie disini, BB saya curve 9360, sudah mati 5 hari dengan error 102 (reload software). Sudah coba ikut instruksi dari
  • How to fix an error 102 reload software blackberry torch ... www.askmefast.com > ... > Error How to fix an error 102 reload software blackberry torch 9810? ... How can I fix reload error 102 on blackberry torch 9810? Comment. Reply. Report.
  • ERROR 102 www.blackberryos.com/general-blackberry-issues/38452-error-102-a.html
    • 2 POSTS
    • FIRST POST: 2013-08-12
    2013-08-12 · how do i reload software on a bb 9360?? ... Join Date Dec 2010 Location Gainesville, FL PIN Jarmeling Device Passport OS 10.3.2.2134
  • May 20, 2016 | Cell Phones
    Will unlocking my verizon bb 8330 with jvm error 102 fix this phone
    codes is 12345 or 00000 u can use it
    Default 4 Digit user code: 1234 or 0000
    Default 6 Digit Security code: 123456 or 000000
    Jul 27, 2012 | RIM BlackBerry? Curve 8330 Cellular Phone
    Reading jvm 102 error rest
    Hi, you have to follow the instruction below to correct the jvm 102 error reset problem..
    Step 1
    Very Important!!!!
    It is important to have the following software installed on your computer (at home and at work if you can):
    1 - Desktop Manager - Hopefully this is already on your computer, if not click here:
    https://www.blackberry.com/Downloads...93E4F3BB068C22
    2 - Device Software for your BB - Here is the link for you to get the latest OS for your Blackberry
    http://blackberryforums.pinstack.com...ll_models.html
    3 - Java Commander - You can download it here:
    http://blackberryforums.pinstack.com...d=5&linkid=452
    4 - Backups - You should be creating a backup of your device data regularly, e.g., as often as you update your calendar and/or phone book, or at least once a month. If you do not already have a data backup, you are out of luck (SOL) as your data is gone.
    STEP 2
    The Process
    From Pinstacker JTReeves:
    You should be creating a backup of your device data regularly, e.g., as often as you update your calendar and/or phone book.
    If or when you get a JVM Error 102/Reset message, do the following:
    1. Connect your BB to the computer.
    2. Run JL_Cmder
    3. Choose option 5, wipe the device. This will delete all files - OS and data - from your BB. The BB screen will show JVM Error 507. This means the BB has no files installed.
    4. Using Desktop Manager, reinstall your software. When you run the Application Loader, check all the available boxes.
    5. When this process completes, restore your most recent backup file.
    You should be back to normal, with the exception of having to reregister OTA or other 3rd party apps. Save their reg numbers in your Memo app so that you have them handy.
    Jan 18, 2011 | RIM BlackBerry Storm 9530 Smartphone
    I have a blackberry 8330 when i put on the phone . theres a white screen that says jvm error 102 reset
    i have a blackberry 8330 when i put on the phone . theres a white screen that says jvm error 102 reset
    Dec 27, 2010 | RIM BlackBerry? Curve 8330 Cellular Phone
    Mar 29, 2010 | RIM BlackBerry Storm 9530 Smartphone
    How to reset if JVM error 102 is hown on the
    Try to replace the firmware / system software of your BlackBerry Boild 9700 to fix your initialization errors. The latest BlackBerry Bold 9700 system software is available through here.
    Jan 21, 2010 | RIM BlackBerry Bold 9700 Smartphone
    Jvm 102 error locks up my blackberry 8330. What
    this problem generally occurs when there is a software problem ......take backup of the handset using desktop manager and reload the software ...
    May 15, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
    JVM Error 102 Reset
    JVM Error 102 (death screen) is going to require that you do a complete reinstall of the BlackBerry OS. Here's a quick FIXYA for the JVM error > here
    ** If you still have issues completing this let we know and we can perhaps provide further assistance.
    Sep 25, 2008 | RIM BlackBerry 7250
    Blackberry jvm error 102
    mt blackberry has a problem. it displaysjvm error 529
    Jul 15, 2008 | RIM BlackBerry 8700g Smartphone
    RIM BlackBerry Storm 9530 Smartphone Logo
    1,111 people viewed this question
    Top RIM Cell Phones Experts
    RONALD CARTER JR
    Ekse
    William Norris
    William Norris
    Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
