If this is a MiniMax NT STD heater, the part on the right on the bottom is not the ignitor, it is the flame sensor. The part on the left with 2 wires is the ignitor. The E04 code is for a fan failure. This means that either the fan is seized, or the air switch is bad, or the air switch tubing is cracked (this is most common)
If you hear the fan is going, then turn off heater and check the air tube connected to the air switch (3" round disk on right side under the square steel enclosure with 2 wires coming off it on the front).
Remove the tube and inspect it to make sure there are no cracks.
If the tubing is good, and the fan works, you need a new air switch.
If you know how to use a multimeter and/or just need more help, you can reach me @
[email protected]
