Question about Home
I have been told there is a way to adjust bath tap temperature under the bath is this true? Thanks
Ned White
  • 2,100 Answers
Yes and no, depends on what tub you have and what is underneath. Most tubs have the filler spouts up top like a regular old tub. If you want more hot water, you just open up the hot water, but if your tub fills from the bottom somehow, or has a heating unit in it, then it can be adjusted. It has a motor under there for pumping the water around. It is in a trap door on the tub or the tub surround. You will have to peek in there to see if there is a water valve with thermostat of some sort. I have never seen one, but you never know. Hope this helps.
Posted on May 17, 2010
I had True Refrigerator model GDM 06, It was cold and freed all my stuffs. I try to adjust temperature warmer, but unable to locate the temperature controller. Please help. Thanks
I had the same thing happen to me and all I needed to do was vacuum the coils of refrigerator. Try this 1st. Thank you. Please leave feedback
Jul 10, 2016 | True Refrigerators
I'm runnin out of hot water in minutes.Baseboard is fine.The hot water pipe off the boiler is hot and it goes thru a dial or adjuster to the taps.And it's warm/cold after that dial. Where do I start?
that adjuster is there to reduce the water temperature so that scalding from boiling water doesn't occur
they can be adjust but if this problem has come in after a period of time then the sensor wax inside the adjuster is not as it should be.
they do fail and need replacing
most plumbers put the unit on the hot water outlet because they are lazy as the standard says that it is primarily for use on the shower, bath, basin systems and wash machines and kitchen sink are not required to be temp controlled.
Apr 20, 2015 | Water Water Heaters
How hot should the water in the bath be when i bathe my baby?
The water should be warm but not hot. 37 celsius is the ideal temperature.
Feb 25, 2013 | Baby Gear
Noisy shower/bath mixer unit
You have low pressure connect cold supply to mains
Sep 19, 2012 | Home
How to changed the temperature?
There should be a thermstat under the cover you can adjust.
Feb 01, 2012 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
How do I remove cartridge part # 9273000 from my Hansgrohe kitchen faucet?
Please contact us at the below number or email me directly and I will get you a copy of the instructions that you need.
Regards
Chris
Christopher Scott
Technical Support Specialist
Hansgrohe Inc.
1492 Bluegrass Lakes Parkway
Alpharetta,Ga 30004
Tel:1-800-334-0455
Fax:678-762-7042
Email:[email protected]
Feb 19, 2011 | Hansgrohe 06649860 Solaris Single Hole...
Hi i have installed a few bosch gas geysers at our lodge in mozambique.The problem is that the water gets hot when we turn the water on then the heat just shuts off and the water gets cold after a short...
The problem with all that type of water heater is that once the hot tap is turned on sufficient flow must be maintained through the water heater to keep the main gas burner alight. If the heat adjuster is turned up to high, then the person using the hot water will turn it down to a low rate which means the main burner will turn off and result in cold water. Try setting the heat control to the lowest setting that still gives hot enough water. If you have a thermometer adjust control for a temperature of around 50 to 55 degrees Celcius. You may have to fiddle with fine adjustments to get the temperature and flow rates to maintain a constant output of hot water. You may still have intermittent problems. If the heater only supplies baths or showers you could set the temperatuer even lower (45 to 50) to ensure that the hot tap is used more than the cold which will maintain flow and therefore heat.
Nov 22, 2010 | Bosch AquaStar Indoor Natural Gas Tankless...
is this a standard bath tub?? if so the answer is no only pressure from hot/cold usually thru the access panel other wise you will have to crank up the water heater unless you have an on-demand water heater located near your access panel. which raises a second question. your faucet? is it a single handle for both hot/cold or two individual handles? if its a single handle try opening up your hot water valve in the access panel to allow for more hot water flow and slightly decresing your cold water valve hope this helps good luck!!!!
Mar 28, 2010 | Home
I am trying to fit a plastic bath panel i have got all the fixings but havnt a clue how to do it! can anyone help?
Assemble the legs & fix to the bath. Leave the adjustment nuts a little loose. Fit taps and waste. Place bath in position. Use a spirit level to ensure lever both front to back and sideways using the adjuster nuts to get it level. Start at one end near the wall and level to the other end against the wall then level sideways. Then check all levels again.
Further help --- [email protected]
Mar 10, 2010 | Home
Home Logo
70 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
