Press the voicemail button and enter whatever extension number you are trying to change. Kisten before you record, to make sure you are in the right place.
You will need to log into Mnager (the IP Office management application). Go to the users section, and click on the Voicemail tab. delete the stars. Then save the config.
When you log in the first time, there isnt a password, so just hit #.
There is no default way to do this. The technician that set the system up will need to tell you the code to get in aand modify that wav file. There is no way to do so by default, it has to be set up, and can be anytihng.
Look at your config, for a short code that goes to a "vociemail collect" with the name recordings.....that is the code you use to modify.
For Partner Voice Messaging.... Dial into voicemail. WHen prompted for the mailbox number Enter 0 # Pswd the default is 1234 followed by # Option 3 is the record Automated Attendant menu prompt
