Konica Minolta bizhub C250 All-In-One Laser Printer Logo
A
Anonymous Posted on May 15, 2010
How to reset the transfer unit (fuse?), do you
How to reset the transfer unit (fuse?) - bizhub c 250 do you have any pictures to solve?
  • himacc
    himacc Jun 14, 2018
    SOLVED
    Change Fuse.: fuse is on the front left side((behind a plastic plate), change for 63mA and it will reset. Is for Konica Minolta Bizhub Fuser and Transfer belt reset fuse's for C200 C203 C253 C353 C250 C252 C300 C352 C350 C351 C450 C451 C550 C650 C452 C552 C652 will save $ 250,=
    https://www.amazon.co.uk/Konica-Minolta-...
Ben
Level 2:
  • Expert 108 Answers
  • Posted on May 17, 2010
Ben
Expert
Level 2:
Answers
108
Questions
0
Helped
89449
Points
277
Hope this helps. Make sure you remove the waste tank prior to taking out the transfer belt. Belt is removed by two screws inside right door and sliding the unit out.
  • advantage846 Sep 22, 2011
    I searched in vain for this fuse until running across this post. Thanks, Bizhubman!!!
  • himacc
    himacc Jun 14, 2018
    fuse is on the front left side (behind a plastic plate), change for 63mA and it will reset. Is for Konica Minolta Bizhub Fuser and Transfer belt reset fuse's for C200 C203 C253 C353 C250 C252 C300 C352 C350 C351 C450 C451 C550 C650 C452 C552 C652 will save $ 250,=
1 Related Answer
xeerie
Zaheer Ahmed
  • 347 Answers
  • Posted on Jun 19, 2010
SOURCE: how to reset the transfer unit (fuse?), do you
search in youtube you will get there, what you want,
1helpful
Konica minolta bizhub c253
what is the question?
Drum, Transfer Belt and Fusing Unit Firmware Reset - http://www.bizhubreset.com
Drum and Toner Chip Reset - http://www.chipreset.eu
Transfer Belt and Fusing Unit Reset Kit - http://www.resetkit.eu
Konica Minolta Error Codes & Solutions - http://www.kmcodes.com
How to know Transfer Belt fuse is gone
The fuse blows as soon as its put in the machine. Thats how the machine knows to reset its count
After BizHub C450 copier has stopped and said replace Transfer Belt, is there anyway to get back up running until new belt shows up
Remove the transfer belt unit and change the chip fuse on transfer unit.The fuse is or a little green pieces or glass fuses ,the value 0,065mA/250V rapid fuse.After change the fuse pull on the unit and turn ON the copier.Before change the fuse reset the transfer belt counter in the Present parts life mode.
3helpful
My Konica Minolta bizhub C250 says replace transfer unit. I have looked for this part and can find nothing listed as a Transfer Unit. There are many parts listed but none specifically says Transfer Unit....
I am sending you this link because A) they have all the parts listed including part numbers and pictures. They are also a good source for parts and supplies. You might find one cheaper on the net tho. Also keep in mind that these transfer belt units are resettable by replacing a $5 fuse in the unit. If you have a local independant repair guy, maybe he can research this and reset your existing unit as they will usually go at least 2 cycles. I reset a dozen or more of these units per year for my customers.
http://www.precisionroller.com/search.php?q=minolta+c250+transfer+
Thank You for using Fixya.
WheatlandServices
2answers
2answers
1helpful
Konica Minoltra Bizhub C250 Malfunction detected C-2451 This message I got after I changed fuse on transfer unit. How to solve it, or at least what this error code means?
hi, from the service manual:
C2451:
Item:
Transfer Cleaner Unit New
Article Release
Description:
A new installation is not detected when a new
Transfer Cleaner Unit (Image Transfer Belt Unit) is
installed.
for the solution, SM says you should try refitting Transfer Cleaner Unit(misplacing could occur) or change the PWB-M board.
2helpful
2answers
Where can I get instructions on how to replace the transfer unit of my Bizhub C252?
Please visit the site http://www.resetkit.eu
There you can find how to reset your fusing unit and transfer kit unit for almost all Konica Minolta MFP's and printers, Bizhub C252 included.
You don't need to replace it, you can just reset it and save a lot of money.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
1helpful
2answers
How do you reset the life of the transfer unit on the Bizhub C250
Yes,
Remove Trasfert belt unit.
On the left handled remove one screw ( spring fixer) and remove right srew (over the belt / bar whit finger fixee).
Remove, on the left spring stoppage and metal handled.
Remove black little srew and take to hand fuse contact.
Change fuse (behind) with new identical fuse and reassembly.
It may be reset trasfert belt counter.
Sorry for my not good english.
Bye.
2helpful
2answers
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
