Question about Sony Handycam DCR-HC42 Mini DV Digital Camcorder
Sony Handycam DCR-HC42 Mini DV not recognized by Windows 7
My Sony Handycam DCR-HC42 Mini dv digital recorder is not recognized by Windows 7 Home Premium 64-bit when connected via usb. This worked fine on xp Pro with my prior pc. Sony support download site says the driver is included with Windows 7 and does not offer a download. I have installed the Sony pmb application but it cannot locate the handcam. Searched the web for another provider of the driver without luck (including Driver Whiz application). Any help would be appreciated. Thanks.
    New Friend:
I have DCR-HC42 video camcorder and now for some reason when I play the tapes the screen tells me to eject tape, does anyone no what this problem is
Posted on Jul 26, 2010
    New Friend:
  • 61 Answers
Get another cheap pc with xp
Posted on May 19, 2010
2 Suggested Answers
6ya staff
SOURCE:
Zygen
  • 85 Answers
SOURCE: Sony Handycam DCR-HC42 Mini DV not recognized by Windows 7
win vista and win 7doesn't support usb streaming. the usb driver for this model would not be compatible with your computer's OS. although, you were able to download PMB still this wouldn't work, it's basically an alternative software that you can use with the newer OS. still the device driver would not be installed. and you would get a message that "ilink connection is not detected". the reason you get that is bec the camcorder and the software is intended for use with the dv (ilink or ieee1394) connection. so if your computer has an ieee1394 card and you have a compatible ilink cable,then your good to go,it should be a plug-and-play connection (no drivers required). all you need then would be a video capturing software (like win moviemaker) to transfer videos from tape to PC. hope this helps. thanks :)
Posted on Mar 30, 2010
I have a Handycam dcr hc21 but windows 7 64 do not recognize it, please!!!! any solution for this problem
http://www.microsoft.com/Windows/compatibility/windows-7/en-us/Details.aspx?type=Hardware&p=Sony%20Handycam%20DCR-HC21%20MiniDv%202.5LCD%2020X%20Camcorder&v=Sony&uid=DCR-HC21&l=en-US&pf=0&pi=2&c=Cameras%20%26%20Photo&sc=Camcorders&os=64-bit
As you can see at the above link, this camcorder is not compatible with Windows 7 64-bit. Don't worry, you have two options:
1) Switch to Windows 7 32-bit
2) Get a analog to digital converter. Basically, a box that takes the yellow, red, white connections out of your camera (using the cable that came with camera) and converts it to a firewire connection to your computer.
A good converter box: http://www.amazon.com/Hardware-ADVC-55-d-Converter-Ntsc/dp/B000HGVZG0/ref=sr_1_7?s=electronics&ie=UTF8&qid=1299245595&sr=1-7
Hope this helps.
Mar 04, 2011 | Sony Handycam DCR-HC21 Mini DV Digital...
Windows 7 64 bit and sony dcr-hc42
Maybe, It doesn't work because the driver you installed. It is for other versions of operating system. I am also using windows 7 like you.Dont worry, You can still use your installer/driver from other versions of operating systems. Before you installing any program/driver in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer first, then choose "troubleshoot compatiblity". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:Djulyallan01_6.jpg
Nov 05, 2010 | Sony Handycam DCR-HC42 Mini DV Digital...
Mar 28, 2010 | Sony Handycam DCR-HC42 Mini DV Digital...
My computer is not able to detect my handycam
Please go to camera menu > settings and enable USB stream option so Windows will detect / recognize your camcorder.
Let me know if this not works to help you out.
Please intimate what Windows you are running in your PC?
Feb 14, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
Sony DCR HC 40 E driver
I had purchased the laptop with Window Vista Home Premium OS. I am unable to connect my Mini DV Sony DCR HC 40 E through firewire. the laptop doesn't recognise mini DV. Please suggest proper driver & solution
Aug 16, 2008 | Sony Handycam DCR-HC40E Mini DV Digital...
Supported USB drivers on Windows Vista
There is no driver available for this model. Sony sucks !!!
May 24, 2008 | Sony Handycam DCR-TRV22 Mini DV Digital...
Sony Handycam DCR-HC42 Mini DV Digital Camcorder Logo
1,656 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Al Rush
Ekse
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
