A
Anonymous Posted on May 15, 2010
Sharp AZAr-5631 Sharp AR-5631 image problem with have some line with have some black emboss line.does need change drum kit unit
abbas rezazadeh
Level 2:
  • Expert 328 Answers
  • Posted on May 25, 2010
abbas rezazadeh
Expert
Level 2:
Answers
328
Questions
Helped
88537
Points
530
Please see the counter of your copier.if is over 50000 change developer.black lines occures when sharger unit above the drum unit is unclean.
2helpful
SC L6-10 ON 5631
i have problem in my photo copier sharp ar203e the problem is op what mean?
The transfer assembly is causing a black line across top of image
Have you done any of the PM kit recently? Has the OPC & fixing unit been replaced recently???? They could be causing lines on copies, there are roller inside the transfer belt that may have toner build up on them...
19helpful
3answers
Reset counter sharp ar-5631
Press the :
( #/P ) key --> ( * ) key --> ( clear ) key --> ( * ) key
clear the misfeed: 24 start --> 1 start
reset the maintenance counter: 24 start --> 4 start
reset the developer counter: 24 start --> 5 start
reset the copy counter: 24 start --> 6 start
reset the printer counter: 24 start --> 9 start
1helpful
Black blotches and streaks on copies
Sounds like a worn drum unit primarily the cleaning blade on the drum is failing. If you don't change it out soon the dirt escaping from the drum and dirty copies will foul-out you fixing unit, = more $$.
1helpful
2answers
Ar 5631 showing maintenance required error
Press the :
5helpful
7answers
Sharp copier ar-5316
That unit uses an AR-016TD Toner/Developer Cartridge. The developer is changed each time you replace the toner. To remove the drum unit open the right side cover, then the front cover, remove the TD cartridge, loosen the green screw on the front of the developer unit housing just above the TD slot. carefully remove the DV unit without tipping or you will spill out the existing DV. Then you can pull out the drum unit. There may be a green screw on the drum that must be loosened but I don't think so on that particular model. Installation is the reverse of removal.
k24674
ADMIN Andrew
ADMIN Andrew
