Here is the service manual: http://elektrotanya.com/?q=showresult&megnev=BENQ&megnev2=FP91&kategoria=&kat2=all
Most of the time you will use flat blade screw driver, starting at the bottom edge to pry open the case then work your way around, also look at YOUTUBE, just search for HOW TO OPEN LCD MONITOR.
BenQ makes monitors for DELL and HP.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
SOURCE: Small text and Icons
sir
sheza
i think you r installed any lan card ar etc. when you had taken com thing from the shop he will geve garenti for minimum one weak. for each component they geve a instaltion cd please instal. and see the system requiredments and proseed to ti ok
SOURCE: Benq FP91G 19'' fades out
Capacitor problem on the power board internal solder fix is possible.
Testimonial: "Quick reply's, great help ....Thanks"
