Alpine NVE-P1 Navigation Add-in Unit for IVA-W505 Logo
A
Anonymous Posted on May 15, 2010
Using IVA-W203 + NVE-P1. Cannot get iphone or Bold 9700 to work. It detects but does not dial or can't hear anything.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 31, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
326
Points
Not a solution, just commiseration - I've had the exact same problem with mine (apparently alpine is aware of the issue) and I've had about *15* different NVE-P1's in my dash to date so far AND i've had them replace the entire head unit as well. Still no dice. :-(
I don't know if this is related, but my Sirius cuts in and out like crazy too - sounds like a loose connection somewhere.
Suffice to say I will *never* be buying Alpine again!
My Blackberry bold 9700 earspeaker not working. what to do
describe the exact situation being faced
if the speaker sound raffled or you are totally not hearing anything the speaker may shifted and you may need to pull the phone apart and put it back in place and ensure that it is tightened, as in screwed down tightly
Lots of things not listed on nav.
Alpine only pays for certain mapping.
This unit will not have the same mapping that say a Garmin would have.
1helpful
I cannot hear the caller when I answer on my Blackberry 9700 but if I call out I can hear them
I recommend replacing the firmware of your BlackBerry Bold 9700. The latest BlackBerry Bold 9700 system software is available through here.
When dialing using speed dial my keypad gets locked or muted. Cant use speaker and nobody can hear me?
When electronic devices start acting up, 99% of the time a firmware rewrite solves the problem. May I suggest upgrading / replacing the system software of your BlackBerry Bold 9700? The latest BlackBerry Bold 9700 system software is available through here.
Where do i get better maps on this nav
Alpine does not have any updates to this 4-5 year old map at this time per Alpine tech support. It is the same out of date mapping as the BT200 - when available, it may be supplied for free... or at a charge from there website - support. Also, having problems with your iPhone 3G syncing your address book. Alpine is having me send in my NVE-P1 and they are replacing the hardware inside so that it will now sync. Also, iPod Touch, and iPhones need at least version 3.0 in order to display video to the W505 unit.
IVA-W203/P1 starts screen shows than gray and wont do anything
Pressing down the reset button for at least 10 seconds may solve the problem. Sometimes media units glich like computers.
You may also try disconnecting the battery for 30 minutes.
Keep me up to date.
Video is off for you safety ?
pac tr7 module will bypass the video lock. the lock comes on if you have the aux on while in drive. shuts off the screen so you cant watch movies and drive. go to amazon or google PAC-tr7 module. costs between 15-30 bucks depending on where you buy it. Very simple hook up, just follow the wire chart.
I have an alpine IVA-W203/P1 but someone broke the screen but it still works and and everything and changes channel but the screen touch screen does not work.. is there any way to fix it so the touch...
If the head unit has a reset button try to reset it. if that doesn't work it will need to be sent to the manufacture to be repaired or replaced. But if someone broke it warranty doesn't cover that. Niether do most insurance companies without special coverage. Sorry.
Top Alpine GPS Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you an Alpine GPS Expert? Answer questions, earn points and help others
