Question about NRS Hoveround MPV 4 - Hovaround Used Electric Wheelchair
Have a Hooveround Teknique FWD wheelchair,
Have a Hooveround Teknique fwd wheelchair replaced circuit board in joystick checked all wiring but 5 lights rapidly flashing. Any ideas please
Donna Angelo
    Novelist:
  • 232 Answers
Five flashing lights indicate Right Motor Wiring Trip- The right motor has a short circuit to a battery. Check all the connections and leads between the right motor and the battery.
Posted on Oct 04, 2010
Where do i start looking for solution svc fwd warning light
Your onboard computer is letting you know that it has detected an electrical problem in your four wheel drive circuits that requires attention. It could be a loose wire, or corroded connections or a switch gone bad. I'd check the connections and wiring first.
Oct 26, 2014 | 2007 Dodge Dakota Cab SLT
Pthe joystck frame is in a bent down position. How do I fix it
It would seem that the support frame is bent. Remove joystick and support from arm. Straighten support and reassemble.
May 09, 2014 | Hoveround Teknique XHD Power Chair - Used...
Hooveround cv5 two years old. Can get no help from them. has batteries about 6 months old. lights on the joystick work but the lights on the battery charger are off. don't know how to troubleshoot
seeelsie Check the charger's fuse located on the front of the case. If you don't see one then you might have to take it apart to see if there is a fuse inside the charger. Check it to make sure it hasn't blown. If you are getting no lights when you plug it into the wall outlet (at least the red light should be lit) if not and you can't find a fuse then you will have to replace the charger. Maybe you know someone with a chair that has an external charger you could borrow for a few hours to charge your chair until you can get one. any external or offboard charger will work so look around for the best deal. Hope this helps
Jan 20, 2011 | NRS Hoveround MPV 5 - Used Power...
Have a Hooveround Teknique FWD wheelchair, all lights rapidly flashing. Any ideas please
A 10 bar flash indicates An excessive voltage has been applied to the VSI. This is usually caused by a poor battery connection. Check the battery connections. Make sure it is not a 9 bar flash, that is an easy fix by resetting the manual brake levers. Check this site for more info:
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Oct 11, 2010 | NRS Hoveround MPV 4 - Hovaround Used...
Have a Hooveround Teknique FWD wheelchair, replaced circuit board in joystick, checked all wiring, but 5 lights rapidly flashing. Any ideas please
5 bars indicate a short circuit from the right motor to the battery. Check all the connections and leads between the right motor and the battery.
Mar 27, 2010 | NRS Hoveround MPV 4 - Hovaround Used...
Hoveround mpv4 does not work led flash when turned on. 3 red 4 yellow and 1 green leds. the brakes, motors and wires have all been tested and work. Any Ideas?
This 8-light code is a joystick controller problem. It is an internal problem with the circuit board located inside the joystick. The entire joystick assembly would need to be replaced in this situation. If you are in need of a joystick, I have several for sale.
Jun 21, 2009 | NRS Hoveround MPV 4 - Hovaround Used...
FWD/DND light is on and so is an extension light but the FWD/DND setting is off but when i check messages, i get a busy signal.
If the FWD/DND light is lit solid, the extension is in DND if it's programmed properly. You can test this by pressing the FWD button and reading the display. It will clear and press it again and it will set and tell you what it did. (if DND and FWD are both set it shows 3 states).
At the phone, press intercom and dial *710x where x=2 for all calls, 3 for busy, 4 for no answer or 5 for busy/no answer plus the extension of the voice mail plus #. Your FWD light should blink and you have now set FWD to voice mail.
Carl
Mar 12, 2009 | Panasonic KX-T7633 Corded Phone
Sony FWD-42PV1 Board Y-SUS 6871 QYH O50C
Hi there I got a YSUS ZSUS Control board kit off ebay. It is supposed to fix the problem. $35 from ebay and $230 from Sony. Lets hope it works
Apr 01, 2008 | Sony FWD-42PV1 42 in. HD-Ready Plasma...
NRS Hoveround MPV 4 - Hovaround Used Electric Wheelchair Logo
201 people viewed this question
Top NRS Health & Beauty Experts
Michael Thomas
Michael Thomas
ray gallant
Are you a NRS Health and Beauty Expert? Answer questions, earn points and help others
