Sampo PME-42V3 42 in. Plasma Television Logo
Question about Sampo PME-42V3 42 in. Plasma Television
Need universal remote control code for maxent 42" plasma tv?
Need universal remote control code for maxent 42" plasma tv to program my dish network remote to operate tv..
Posted by fess_server on
Becki Barned
    Novelist:
    Champion:
  • 286 Answers
I hope that you have gotten this resolved, but if not, or if you have any other questions, here are the codes and some simple steps to run through.
1. Hold down the clear TV button until all lights light up at the top of the remote
2. Punch in a 3 digit code (provided below)
3. Press the # (POUND) button
4. Try powering the tv on/off, and the volume. If one or more of these functions do not work, start over from step 1 with a different code
246
730
746
Becki Barned
DISH Network Customer Service
Posted on Feb 02, 2011
2answers
Dish network remote control and akai tv
Not likely the Dish remote will have that remote code at all in it--some of those sets were made by Samsung so try those codes also.
3answers
Does anyone know the remote code for a sanyo tv model dp42647 on a dishnetwork remote
Remote Codes ' MyDISH ' DISH Customer Support
https://www.mydish.com/support/remotecodes
Remote Control Manuals · Program Remote to TV/Other .... remote, product type, and manufacturer below to see the current known remote codes you should try.
My Dish remote needs programming for Sanyo TV ... - Directly
https://www.directly.com/.../dish-network-my-dish-remote-needs-progra...
My Dish remote needs programming for Sanyo TV, Model DP226649. My Dish ... Needcode. Alta asked this ... Dish Network • 16808 answers • 95% helpful. Code is ... Test volume control, if it works you're set ... try 590 it should work. tivosat.
How do I program my dish remote to work for my Sanyo TV.
https://www.directly.com/.../dish-network-how-do-i-program-my-dish-re...
Dish Network. How do I program my dish remote to work for my Sanyo TV. ... entercode 590 press pound then sat Then try to turn tv on and off then try volume.
How do you program a dish network remote to my sanyo tv? ' Ya
Hi i have MAXENT TV 50" plasma im loking for dish network remonte code to program on it please help
We show no codes listed for Maxent televisions. The best method for programming this remote is called a Power Scan, the steps are below:
Power Scan
1.) Hold down the clear "TV" button on the remote for four seconds, then press 500 pound ( #)
2.) Hold down the clear "TV" button on the remote for four seconds, press the big power button once.
3.) Press the channel up button once per second until the TV turns off then press pound (#).
Daniel Busa
DISH Network
Customer Service
2helpful
I WOULD LIKE TO KNOW IF THERE IS AN UNIVERSAL REMOTE THAT WORKS WITH MAXENT ML3251 HLT LCD TV
i have a 42" MAXENT PLASMA TV & I LOST THE REMOTE CONTROL. MY BROTHER BOUGHT AN ALL IN ONE UNIVERSAL REMOTE CONTROL & SENT IT OUT TO GET PROGRAM. THE CODE IS 1755, & I HAVE ACCESS TO PRETTY MUCH EVERYTHING BUT CHANGING THE INPUT WHILE IN PICTURE & PICTURE MODE
4helpful
2answers
Need code for my maxent tv
Maxent is sometimes the same as SAMPO. Try 746...
Tv remote
I was looking for codes for you but cant find any compatible ones!
You can order the orginal remote for your TV at www.remotes.com
Have make and model ready!
Hope this is a fix ya solution for ya!
Control Remote Codes
Mike,
Code 246 is the correct code for my Maxent plasma for my dish network remote. Remote is 5.3IR and it was made by EchoStar Technologies Corp. Part #142301. If yours is the same, good luck.
jerry
1helpful
Tv remote code
Trying to program a universal remote can sometimes be a frustrating process. Successful programming of a universal remote depends on whether the universal remote manufacturer included our company’s information in the remote when it was assembled.
Then a cable company (ie., Comcast) or satellite provider (ie., Dish Network) orders their decoder box and universal remote control from a manufacturer (ie., Scientific Atlanta, Motorola, etc.), the decoder box manufacturer provides a list of all the possible remote controls this universal can duplicate. From that list the cable company or satellite selects which manufacture’s products to include on their new universal remote. Once those manufacturers names have been decided, they are placed on the universal remote and a numeric code is assigned. If they choose not to include our company on the universal remote, the universal remote may not access the Maxent screen.
If you cannot locate Maxent on the list provided to you by the universal remote provider, please try the following:
Through contact with various cable and satellite content providers we have developed a list of the most common numeric codes that are used with universal remotes.
Content Provider/Most commonly used code
Comcast: 1755
Comcast (ML-3251HLT Model): 0054
Insight: 1755
Direct TV: 11755
Dish Network: 742
Cable Vision: 165
Adelphia: 0156, 1755
Universal: 0762
One4All: 0036
Time Warner: 0230
We have identified other manufacturers of display products that have similar remote control information to ours. Depending on the universal remote you are using these manufacturers may work. Please use the documentation that accompanied your universal remote, and look up the following companies. Input the numeric code associate with that company.
Gateway
Sampo
Viewsonic
Magnavox
Phillips
Marantz
Pilot
If the universal remote you are trying to program contains a Code Search (the remote will scan through all the codes contained within the universal remote) function, we recommend that you try that procedure. It is possible that there may be another manufacturer code that may work with our monitor.
You may also want to try a Learning Remote from another manufacturer. This type of remote control can absorb or record the information coming directly out of the Maxent remote control. The learning remote then duplicates that information and acts like the Maxent Remote control. This type of remote can also record the signal coming from your other universal remotes in the same manner. In which case you can use this learning remote for your entire audio video system
please rate the chat session that got disconnected due to slow server if this helps.and if does not helps please reply for further help.
6helpful
2answers
Maxent MX-42VM10 42 Remote
Comcast: 1755
Insight: 1755
Direct TV: 11755
Dish Network: 742
Cable Vision: 165
Universal: 0762
One4All: 0036
Time Warner: 0230
Gateway
Sampo
Viewsonic
Magnavox
Phillips
Marantz
Pilot
Hitachi Plasma
i have dish network different brand tv but have codes for hitachi they are 1004,1006,1012,1013,1059,1060,1063,1135,1136,1145,1148,1179,1185. hope one of these helps
Top Sampo Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you a Sampo Televison and Video Expert? Answer questions, earn points and help others
