Good am how can I repair the speaker of my lenovo laptop? It sounds grounded and not clear.. Can I replace it with a desktop speakers instead? please help. thanks
Hi. regarding the question about replacing it with a desktop speaker, yes you could do that but if the problem is with the drivers for your audio then that would not fix the issue, because even if you change the speaker hardware but the problem is with the software then it would still output the same grounded sound. The best way to fix this is first, try to use the desktop speaker and plug it on the speaker port on your laptop and if its output is clear that means the problem is with the hardware built in speaker of your laptop but if the output sound is still grounded the you should download the latest driver for the audio of your laptop from the lenovo website or you could also call their tech support hotline at US/Canada 1-800-426-7378, Australia 1-300-880-917 and if you are still under warranty then they could just replace the speaker of your laptop. Hope that helps
