Sony Cyber-shot DSC-H2 Digital Camera Logo
Posted on May 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The button that you press to make a photo came off the camera, and it won't depress to make a photo now. Is there a spring or something missing? If so, would a local camera shop be able to repair/replace it, or will I need to send it back to Sony? Thank you!
Anonymous
Level 3:
  • Master 10,594 Answers
  • Posted on May 17, 2010
Anonymous
Master
Level 3:
Answers
10594
Questions
9
Helped
2955193
Points
33084
Shutter button is available in parts shops and local camera repair shop will replace it.
Sony will charge you too much to replace that button.
Let me know if you have any additional question.
Thanks.
Anonymous
Level 2:
  • Expert 489 Answers
  • Posted on Nov 09, 2010
Anonymous
Expert
Level 2:
Answers
489
Questions
Helped
139184
Points
960
The Sony DSC-H2 and DSC-H5 have a terrible shutter button design and Sony will not admit that it's a design problem. The post for the shutter button is so thin that it snaps in half very easily!!
If you do a Google search for "Sony shutter button repair" you will see the #1, 2 and 3 links are all for www darntoothysam com. We have done hundreds of this repair over the years!
The repair service is just $70 total for the part, installation and return shipping of the camera. Please visit our site, we would be happy to service your camera.
Hope this helps!
Thomas D.
Owner, Darntoothysam.com
Affordable Digital Camera Repair
Why are my photos blurry
I would think that you are not focusing your camera before fully depressing the shutter button Start by depressing your shutter button very lightly until you see the outline of a small square in the middle of the view finder . At that point you are in focus . Now fully depress the shutter button and take your picture . You must do this prior to taking each photo . Remember to just depress the shutter button about half way to focus your picture image , before pressing it fully . I hope this is of some help to you.
Apr 06, 2017 • Cameras
Photos always blurry not clear
There should be a stability setting on the camera - an automatic one.
T3 built in flash won't pop up. Says I have an external flash attached, but I don't.
There is a small flat leaf spring under the hot shoe rail where an eternal flash slides in. If an external flash is mounted the leaf spring is pressed against a small button telling the camera that there is an external flash mounted. Take a toothpick and rub under the hot shoe rail gently to more the leaf spring or unjam the leaf spring. You may even see the button depressed, poke at it a time or two with a toothpick, even a drop of rubbing alcohol may unstick this button if a sticky beverage sprayed on it.
My N55 won't let me depress the shutter (to take the shot) when it's on automatic setting. I depress once (half-way) for autofocusing--which seems to work fine. No error message. But then, the N55...
Could be your lens is not communication with the body. If the lens is not telling the camera that the AF has locked on an object then it won't allow the camera to fire. Make sure that the camera is indeed locking the AF on the object. If there isn't enough contrast (for example a plain wall) then it wont be able to lock onto it. This would usually explain why it works on manual but not on auto (I assume you mean the focus setting and not the camera's modes). If you're still having issues I recommend you contact a nearby Nikon authorized service center for assistance and possible repairs. Hope this helps!
Hiram
Photo Tech Repair Service
110 East 13th Street
New York, NY 10003
212-673-8400
1helpful
2answers
With camera on the AUTO setting, I can't seem to take clear, focused photos. Nearly all of them are out of focus or blurry. Does not matter if it is in the day time or at night. Also, when using the...
Try resetting your camera back to factory defaults. Press the MENU button, select the middle tools tab and scroll down to RESET ALL. Press SET, select OK and press SET. Hope this helps.
The button to depress to take pictures is missing do you know where I can get it repaired?
Actually it's extremely simple to repair. You just reinsert a new shutter button into the hole with its spring. It just snaps in place. Unfortunately, that little part is not inexpensive. There's a fellow who sells them on eBay if you want to pay the price.
2helpful
Missing pictures
Lets check the SD card first.
Take out the SD card and put it in external card reader connected to computer.
Copy/transfer all the photos from the SD card to computer.
goto My Computer and right-click the 'Removable Disk' (the SD card drive) and click Properties.
click Tools and click Error checking - Check now button
select the option 'automatically fix file-system errors' and click Start button.
if any errors was found and fixed, you can also Format the SD card. And your SD card should not drop photos again.
Now put SD card back in the camera.
Now take 20 test photos and check if something is missing.
if not take 20 more test photos and check if something is missing.
if all is ok then you can delete all test photos and start taking normal photos.
9helpful
2answers
Internal memory photos download to sd card
1. Ensure memory card is inside camera.
1. Turn on camera.
2. Press Review button on back of camera
3. Then Press Menu Button on back of camera
4. Select "Image Storage" option (by depressing the joystick on RHS of back of camera).
5. Select "Internal Memory" option (by depressing the joystick on RHS).
6. Select "Continue"
7. Press Menu button.
8. Press "Review" button
9. Press "Review" button again.
10. Press "Menu" button.
11. Scroll down to "Copy" and select this option by depressing the joystick.
12. Scroll down to "All", then select by depressing the joystick.
13. Contents should now copy over from internal memory to SD card.
14. Don't forget to reselect Auto detection of SD card afterward. This is done by turning camera off then back on again. Press "Review". Press "Menu". Select "Image Storage". Select "Auto". Select "Continue".
1helpful
Deleting
Press mode button until you get the icon of photos with a line thru it.Then depress and hold button used to take photos for 3 secs. There will be a series of beeps and the photo counter will show "0".
Top Sony Cameras Experts
ZJ Limited
ZJ Limited
Are you a Sony Camera Expert? Answer questions, earn points and help others
