It sounds like your fridge has problem with the damper stuck open. The damper is in the top-back-center of the fresh food section. I can't tell by the pics I have how to get to it, but looks like it's simple to get to it - just remove the damper cover.
Check the damper for the ice buildup. Clean if needed. Unplug the fridge and check continuity on damper motor. Replace damper if no continuity.
Check the microswitch on the damper assembly. C on switch [where it connects to black wire] should make contact with NC [yellow/red] when button is not pressed, and C with NO [blue/red] should make contact when button is down).
With temp in the fresh food section so low, the damper should be closed, and if it isn't there should be power (110v ac) coming to the motor either continuously until it closes or for a short period of time within a few minutes after you try to set the temperature, can't tell by schematic. Unplug, connect your DMM in "volts ac" parallel to the damper motor (red and green/yellow wires), and plug fridge back in. If it does not show 110v immediately, set the DMM to show the maximum voltage registered, and leave in the fridge for 20-30 minutes, with doors closed. If there was 110v, and the damper is still open - replace damper. Otherwise it's very likely that the control board failed.
Parts:
Damper assembly:
67003903Control board:
12782036SPIf you order from that site, use "New10" coupon code for 10% off.
