Question about Sharp Televison & Video
Can,t record from digital channels
I have a Sharp combi vhs/dvd DVRW360H and a Philips 26PLF7532D TV with Freeview.
The problem I am having is that I cannot record the Freeview unles the TV is on.
I have tuned in all terrestial channels on the Sharp, but
the Digital channel wont tune in. Can anyone help?
Posted by mildeuk on
Kev Bushell
    Habit-Forming:
    New Friend:
  • 108 Answers
You’re dvd/vcr only has analogue tuner so the only way to record is by using the Phillips tv but as said tv will need to be switched on.you would need a sky or cable box or a free view box separate to the tv to record with tv off.the vcr will recieve only on the av channel av1 when connected to tv.a sky box or cable can be connected to av2 on sharp using a second scart lead and box
Posted on Feb 05, 2018
5 Related Answers
Anonymous
SOURCE: Connection problems with Philips DTR220
There is such a thing as a HD areial, but in this case it sounds like you need to point the antenna in the right direction. If your freeview is digital then there is a diredtion the areial needs to piont, and there is a front and a back to it. You need to find where the signal source is located and point the areial in that direction.
Posted on Mar 31, 2008
Slinteriors
Sonny Berry
  • 8617 Answers
SOURCE: I have a philips tv
here is a link to the phillips universal remote page that has all the codes for any brand tv including phillips and it will explain how to program the remote try the codes for phillips one of the codes should work.
http://www.universal-remote.net/philipsmagnavox.html
Posted on Apr 08, 2008
biggings
SOURCE: I have been given a
Found a download PDF manual on Philips' website
Posted on Jun 13, 2008
Anonymous
SOURCE: how do i tune my philips 3590H philips dvd recorder into digital
The User Manual for your DVD Recorder is available here... http://www.p4c.philips.com/files/d/dvdr3380_05/dvdr3380_05_dfu_eng.pdf
Info related to your specific problem is as follows...
Setting your TV channel
programmes
Before the recorder can start recording
the TV channel programmes, you need to
search for the available TV channels and
store them in the recorder.
Note: Make sure you have successfully
made all the required connections to the
recorder, the TV and Satellite Receiver/
Cable Box (if any) and switched them on.
Tuner settings can only be changed
when there is no disc in the disc tray.
A Press SYSTEM-MENU on the remote
control.
�� The system menu appears on the TV.
B Use ���� keys to highlight
{ System Menu - Channel Setup }
and press ��.
Modify Channel Information
Sort Channels
Channel Search
Edit
Sort
C Use ���� keys to highlight { Channel
Search } and press OK.
�� The automatic TV channel search
starts. This process may take several
minutes. Once complete, the total
number of channels found appears on the
TV.
Automatically scan all the receivable analogue local TV
channels and store these channels on the recorder.
�� Use ���� keys to highlight { Channel Search } and press OK.
�� The automatic TV channel search starts. This process may take
several minutes. Once complete, the total number of channels found
and stored appears on the TV.
Modify Channel Adjust a stored TV channel to your preference, improve the
Information reception and the sound quality of that TV channel.
1) Use ���� keys to highlight { Modify Channel Information } and
press OK.
�� The channel menu appears.
2) Use ���� keys to select one of the options.
{ Name } – You can use the numeric keypad 0-9 to select
the channel preset number which you wish to
change.
– Use ����keys to change alphabet/ number and
use ���� keys to select different entry fi elds, then
press OK to confi rm.
{ Scan Mode } – Select TV channel search mode based on
channel allocation or frequency.
– Use ���� keys to select { Frequency },
{ Channel } or { S-Channel } (Special Channel),
then press OK to confi rm.
{ Frequency } – Shows the frequency of the current TV
channel.
– If required, use ���� keys to start the automatic
frequency search and press OK to confi rm.
{ TV System } – Set the TV system that produces the least
distortion of picture and sound.
– Use ���� keys to select a suitable sound mode,
then press OK to confi rm. (See chapter “TV
System Guide” at the back of this manual for
more information).
{ NICAM } – Turn on or off the digital sound transmission
system which improves the sound quality of the
TV channel.
– Use ���� keys to select { On } or { Off }, then
Posted on Jan 01, 2009
Anonymous
  • 121 Answers
SOURCE: im trying to tune in tv channels without the remote control can this be done
try buying a cheap one for all controller.
Posted on Apr 28, 2009
How do i record using my sharp DV-RW360
Hi.Here is a site that will help you:-
Free Sharp DVRW360H DVD VCR Combo User Manual ...tv.manualsonline.com/manuals/mfg/sharp/dvrw360h.htmlDownload a free copy of the Sharp DVRW360H DVD VCR Combo User Manual UserManual.
May 08, 2012 | Sharp DV-RW340U DVD Recorder/VCR
LG RH266 setup with freeview tv
Sorry to say no it wont not unless the Tv set manuel says it has a Duel Freeview feed , you have to get another freeview box for the recorder .
besides If you used the freview in the tv 1 , the tv would have to be on when you wanted to record ?. and 2 you couldnt watch another channel whilst recording another .. only 1 tuner ?. also you could only record the program you had on .at the time no timer facility .
People are still used to the Old system of VHs and the fact that all videos had tuners built in so you could watch and record .. It will come and indeed some more modern DVD recorder have freeview built in again sorry but thats the facts , and dont forget if you want the pay per view channels on free view your going to need a tuner with a pay card port ... Regards Vortash
May 12, 2009 | LG RH266 Recorder
Connect philips dvdr80 to intigrated freeview tv
Solved the problem by connecting the freeview box back into the dvd recorder. Apparently because the dvdr was made before tvs with integrated freeview, it can only recieve decoded signals from a freeview box, ie analog
Jan 16, 2009 | Philips DVDR80 DVD Recorder
I have a Philips DVD Rcorder How can I record a programme but watch another one at the same time. Has Freeview installed.
When you have programmed the DVD to record a channel, you can only watch another channel from your TV's channels, or a second freeview box.
The DVD recorder can only be set to one channel at a time, even though it has separate analogue & digital tuners.
Jun 01, 2008 | Televison & Video
Similar problem as you helped me solve before.
OK, I think I see the problem there.
The aerial lead from the DVDR to TV should be removed.
You should have it setup the same as the other Freeview - VCR - TV
Nutshell time:
Main aerial to Freeview input.
Loop aerial from freeview output to DVDR areial input (all this does is allow you to watch freeview, or standard both out of the DVDR)
So..
Scart from Freeview to DVDR input
Scart from DVDR output to TV
Set DVDR to AV input mode.
Set TV to AV (whatever number you need for that..you now won't get anything on screen unless you have the right input selected)
If you can now see the Freeview picture on the TV and change the channels with the Freeview remote then you should be set for recording.
Having the aerial and a scart lead both going to the TV is not needed.
Apr 14, 2008 | Philips VR550 VHS VCR
Can't record Freeview
You should have the Freeview box connected to the VCR, then the VCR to the TV
Hope that helps =)
Apr 12, 2008 | Philips VR550 VHS VCR
Sharp VCR/DVD recorder combi DV-RW360H
Click the link at the foot of this posting.
In the select a product code, look for DVRW360H
To find the manual click >HERE<
Mar 01, 2008 | Televison & Video
Samsung Digital TV and Sony DVD Recorder
hi, did you find a solution? i have in built freeview and have bought a recorder but i cant pick up any freeview channels on it. the dvd recorder is a Wharfedale DVDRHD400 cheers tom
Feb 11, 2007 | Samsung 4 CHANNEL DIGITAL VIDEO RECORDER...
Televison & Video Logo
Top Sharp Televison & Video Experts
Demonic-2011
Demonic-2011
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
