Question about Garden
I have 5.5hp briggs&stratton pressure washer Simoniz S2350. Would you know the PSI for this item?
Posted by jagjitgirn on
  • Anonymous May 16, 2010
    I went to Simoniz's website, and they dont seem to carry (or display) the model you have, check their website and see if they have the model that you own.http://www.simonizusa.com/consumer/Conte... If you have any questions please let me know. Thanks, Mike
Kelly
  • 3,740 Answers
Every 5.5 HP pressure washer runs between 2,200 and 2,500 PSI with most set by the manufacturer at 2,400 PSI with 3,600 RPM of engine speed.
Due to the power required to produce more than 2,500 PSI a 5.5 HP engine would lose engine speed as it can not produce enough power for the higher PSI output. It is a matter of hydraulics vs input power.
Any gas pressure washer will produce lower pressure with lower engine RPM. Looking at S2350 as your model number yours may be set to 2,350 PSI by Simoniz.
Thanks for using FixYa.
Kelly
Posted on May 17, 2010
Problem with Briggs & Stratton 2400 PSI 190cc Gas Powered Pressur pressure washer, it locks up
Try disconnecting the pressure hose and work backwards after that like remove the unloader valve and so on. Contact Flowjet cleaning equipment for help over the phone.
Dec 03, 2012 | Briggs & Stratton Measuring Tools &...
Pressure washer won't deliver pressurized water.
sounds like you have a blockage maybe in your water hose ,ideally your water hose should be around 25 feet..or you may have an o ring in the gun where the tip goes.. is broken..that will affect your pressure..check also filter where water hose connects to the pump make sure thats clear
Sep 30, 2017 | Briggs & Stratton Briggs Stratton 1800...
I do like to know if this washer is good enough for my business as a used car dealer? Briggs & Stratton Murray 020456 2400 PSI 20 GPM 190cc Briggs Stratton
We power washed houses for years with a 2400psi machine. The machine weighed about 90 pounds. 1 strong man could pick up the weight, but usually it took 2 men to unload it from the trailer.
A small machine can advertise 2400 psi ... but that is for 3 square inches at a time. The heavier machine shoots a 10" or wider swath of 2400psi.
We ran our machine twice a week for years. We had a honda engine. I'm sure the briggs engine is good. I wouldn't buy a used machine... unless the price was low and it started on first pull. Electric starter on your power washer might be a repair-waiting-to-happen because it is constantly exposed to water and dirt.
Oct 19, 2010 | Briggs & Stratton Murray 020456 2400 PSI...
Need to know where oil drain plug is on 6.75 hp Briggs & Stratton engine on 2550 psi troy bilt pressure washer!!
I have the same model...... it should be just underneath the unit.... it will look like a square head recessed. I used the ratchet set extension and it fit just right. I literally had to tilt the darn thing upside down to find it. Then once it was loosen a bit, I put the machine upright on the wheels again, and slip a plastic pan underneath as I finished unscrewing the oil plug, Out came the black goo.
Aug 07, 2010 | Briggs Stratton 020273 Elite Series...
Oil
Remember when your searching for something you can't find the internet is always your best bet. You should also use a good search engine; www.bing.com is one of the best search engines I have ever used. I searched some stores that have the oil your looking for, one online store is www.amazon.com and if you have one near you and they also carry it at Sears. The grade of the oil is definitely weird, 75W90. Also if you would like to look for other stores that carry it go to Bing and type "Briggs & Stratton Pressure Washer Oil" into the search bar.
May 23, 2010 | Briggs & Stratton Briggs Stratton 2000...
Briggs & Stratton 2500 Power Washer Loses Pressure Time to Time
If by "a few minutes" you mean 180 seconds, I really don't know what to say. But if you mean 5-10 seconds, you probably are experiencing air in the water line or normal engine warm-up behavior when the choke has been set to full lean too soon.
May 23, 2009 | Briggs & Stratton 020324 3700 PSI Pro...
Looking for Owners Manual for Simoniz S2600
Hi my simoniz electrc power washer will not go off when I release the trigger , leaks trough the water inlet hose , I replaced the O rings but keeps leaking ..THANKS
Apr 21, 2009 | Garden
Garden Logo
500 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
