My Samsung TV has horizontal lines runnning across the screen. At first it was only on the left side of the screen. Now the lines are completely across the screen. Watching TV is pointless, as it occurs on both High Definition channels and standard. My TV is a Samsung LN46B640R3FXZA HD TV made in 2009.
SOURCE: Several dozen thin horizontal white lines across the top of screen, all channels
These beasts are monsters to get into and service without the proper extenstion cables and a service manual. there are no user replaceable parts inside this set. if you know solid state serviceing, you can try and fix it. There is a bad capacitor or capacitors in the vertical sweep circuit and or the vertical output IC is bad also. If you can solder and unsolder go for it. But if you do not or know how the circuit Works Please find a trained tech to assist you with this repair. Good Luck. PS please do not forget to rate this.
SOURCE: HDMI INPUT FOR NON HIGH DEF CHANNELS WILL NOT DISPLAY FULL SCREEN
if you have a cable box then it is probably the resolution settings in the cable box, what type of cable box do you have
SOURCE: Mitsubishi TV had horizontal lines across the screen and rolls up
Answer
ONE: Yes, the speaker mounted close/near to the set
can be a cause of mischief; please move it further away and see if that
helps clear up the problem. But, you must keep it away for several
days before you will know for sure because it takes some time to
degauss all the internal parts that may have become corrupted by the
magnets in the speaker.
TWO: Yes, any set can be repaired the question is cost and wisdom.
Old sets are sometimes not worthy of the repair simply because of the
likelyhood that another failure will follow soon after. A big screen
always invokes a repair charge of $200 and up. After a few of these you
will wish you had put all the money into a new set!
THREE: The lines are most likely a problem in the vertical blanking
circuits of the set. These are horizontal retrace lines that are
supposed to be blanked out during vertical retrace of the raster.
Think of it as a paintbrush that scans across the screen painting thin
lines and when you get to the bottom of the screen it goes quickly back
to the top, but during that time the horizontal, which is many times
faster, has made several sweeps; so it must be blanked out during the
retrace. The repair involves finding the guilty parts and replacing
them. Usually this repair runs over the $200 somewhat.
FOUR: Prior to calling in a service tech try a hard reset to see if
that will recover any of the circuit degradations. Merely unplug the
power cord and leave unplugged for 4 hours or more. It may help. Or,
it may not help; but worth a try since is won't cost you anything.
If the set is over 5 or 6 years of age it probably is not a condidate
for any expensive repair. On the other hand, it is a Toshiba - and
they make a fine set.
Hope this helps. Let me know if you have further thoughts.
SOURCE: White horizontal lines across the top three inches
not generally. most places no longer carry parts for crt screens.
Try using a different connection and see if it does it.
