Question about Sony Grand WEGA KF42WE610 42" Rear Projection HDTV-Ready Television
KF42WE610 bad lamp... and ballast?
My uncle had a coworker who had issues with their tv and asked if I could take a look at it. I noticed that when I turn the tv on the ballast has a component that has a pinkish glow for a few seconds and then stops. Originally I thought the ballast was bad, but I checked the lamp and the lamp does need to be replaced. What I don't want to do is replace the lamp and have the ballast blow that right away. Is there any way to check if the ballast is still good? Would I be encouraged to replace both the lamp and ballast in case this is somewhat of a common problem? Let me know please, Thanks
Posted by Tom Fillmore on
  • Tom Fillmore
    Tom Fillmore Jun 04, 2010
    Yeah it was the lamp. That was so simple. I figured the owner had already checked the lamp prior to bringing it to me and I had never seen the pink glow that the ballast was showing.
    Thanks again welcomejee. Your help is always appreciated.
    quick question: why does the optical block seem to fail so often?
Shahid Electronics
  • 10,594 Answers
DLP Lamp has electrodes inside and ballast generates high voltage that makes spark on these electrodes thus got high bright light. New lamp wont die due to bad ballast so replace lamp and see tv works or not.
This tv has self diagnostic feature, turn On tv and let it shut down, now check standby light that would be blinking in specific order, for example 3 or 4 times blink then pause for 3 seconds and again blinks.
Let me know how many times standby light blinking in this tv to help you with more info.
Thanks.
Posted on May 16, 2010
TV shuts off by itself
I would think a ballast would be easy to change take out old put in new like for like
Nov 07, 2013 | Panasonic PT-43LC14 43" Rear Projection...
After replacing a bulb, when power on, it flash first green and goes to flash red continue to flashes red about 5 flash each time what should i do?
5 is a lamp driver fault, could be a poorly seated bulb or a bad ballast. Usaly it is a bad ballast. Previous bulb failure could have dammaged the balast.
May 07, 2010 | Sony Grand WEGA KF42WE610 42" Rear...
Sony KF42WE610 Picture
Hi iverson_101
This could be a lamp issue. The easiest way to be sure is to take out th lamp and check for any irregularities on it e.g. white or black vein like looking marks , a buuble at the end of the shaft or a broken fillament.
If cannot spot anything this could rather be a Ballast ( lamp's powersupply ) that has gone faulty and will have be replaced.
Thanks for using Fixya and good luck !
May 25, 2008 | Sony XL-2100U Projector Lamp for...
Tv turns itself off after a few moments of clear viewing
HLP, HCN HL-S The Start-up Problem or/and
3 LEDs in the front blinking.
Unplug the set, pull out the lamp module (not all the way - leave it on the track) and push it back in.
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues
good luck
please mark the post with a fixya!
Feb 07, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung 42 inch projection
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Feb 07, 2008 | Samsung HCN4226W 42" Rear Projection...
Replaced lamp still not working
Power issues (Tv True True (``````````` (``````````` 0 95250 95250 clip_image002.gif not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung True True (``````````` (``````````` 0 95250 95250 clip_image002.gif is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Jan 16, 2008 | Samsung HLN5065W 50" Rear Projection...
My tv turns off
Jan 16, 2008 | Samsung HL-R6167W 61" HDTV
My projection tv
Nov 23, 2007 | Samsung HLN5065W 50" Rear Projection...
Samsung SP43W6HPX\XEU Rear projection
Oct 25, 2007 | Samsung HCN4226W 42" Rear Projection...
Sony Grand WEGA KF42WE610 42" Rear Projection HDTV-Ready Television Logo
609 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
