Question about Whirlpool Ultimate Care II GSW9650LW Top Load Washer
Agitater trying to function but does not
It began making a noise like the gear was stripping out now it will not agitate at all. All other cycles work as they should
Posted by gregkelly966 on
Anonymous
    New Friend:
  • 20 Answers
Chances are high that the gearbox has expired!
Posted on May 16, 2010
Will not drain, spin or agitate
make this test and fix it. God bless you
First you will need to identify if you have a direct drive type or a belt drive. The later is obvious if you have belts under your machine it is a belt drive, if not it is a direct drive. Also there are 2 basic agitator types with some variances among them. The 2 piece and the single.
Agitator Dogs
The agitator dogs are in the 2 piece type of agitator. These wear out over time. They also break and can cause noise. To inspect and replace the agitator dog .
Agitator Coupling / Spline
The other type depending on age of your machine use a spline. Newer GE types have a coupling that gets stripped out and the older GE type has a spline directly on the agitater that gets stripped out. You will need to remove the agitator. The dispenser usually pulls right out. This will give you access to the bolt that holds the agitater down. Remove the bolt, then place your fingers under the agitator and pull up. This can take some force. A belt slid under the agitater can also work. Once off you will see if it is stripped or not.
Belt
If your washer is a belt drive type make sure the belt is tight. Check for black soot from belt wear. Replace if it has excessive wear or broke.
Motor Coupler
This is a fairly common problem with direct drive machines but inexpensive and easy to replace. The Motor Coupler transfers power from the motor to the transmission. The following video will walk you through the replacemente motor coupler.
Transmission
The transmission does not usually fail. To check this on a direct drive remove the motor and then turn tub inside. If it spins freely with no noise the problem is elsewhere. If it is noisy it needs replacing this is expensive and depending on the age of your machine you may not want to replace it. On a belt drive remove the belts and spin tub.
Jul 25, 2013 | Washing Machines
Vbsr2080woww
follow this steps and fix it. God bless you
Agitator Dogs
The agitator dogs are in the 2 piece type of agitator. These wear out over time. They also break and can cause noise. To inspect and replace the agitator dogs follow video.
Belt
Motor Coupler
This is a fairly common problem with direct drive machines but inexpensive and easy to replace. The Motor Coupler transfers power from the motor to the transmission. The following video will walk you through the replacemente of motor coupler
Transmission
Jul 09, 2013 | Washing Machines
Agitator not working wont wash water does drain
see this steps and fix it. GOd bless you
Agitator Dogs
Belt
Motor Coupler
This is a fairly common problem with direct drive machines but inexpensive and easy to replace. The Motor Coupler transfers power from the motor to the transmission. The following video will walk you through the replacement of motor coupler
Transmission
Making an awful ratcheting noise during aggitation and spin cycles
Under the agitator there is a rachet mechanism that works the agitator. If it is stripped, it will skip until the next good tooth.. when it fails entirely the agitater will stop going back and forth. Its nylon and age along with overloading hastens its dearg.. If you can get the parts you can replace it yourself without difficulty. There is a single bolt in the center of the agitator top . Remove and loft agiyator straight up.
Jun 03, 2009 | Maytag Legacy Series Top Load Washer
Agitater problems will not agitate
To Reset computer. Unplug for 2 minutes, plug back in, open and close lid 7 times slowly to reset computer. This should solve your problem.
May 09, 2009 | GE WBSR3140DW Top Load Washer
Agitator in washer is making lots of noise
there is a racheting gear made of plastic under the agitater. if the tub is overloaded it will strip the gear.
Feb 22, 2009 | Washing Machines
My ge washer wpre6100g clicks during agitation part of cycle...
sounds like the agitater drive is stripped its a plastic piece under tha agitater you just grab the agitater work your fingers under the edges and **** up on it and it snaps off then remove the 5/16 screw put a new block on and snap the agitater back on
Jan 29, 2009 | GE Profile WPRE6100G Top Load Washer
Terrible noise when agitating
Your transmission has gone out. The reason the spin cycle works is because the transmission spins two different ways and you agitate way stripped the gear. Some places rebuild them. Try with your local stores maybe they can rebuild it or get you a good used one. If not you can order a new one from sears.com
Nov 12, 2008 | Kenmore 24032\24036 Top Load Washer
Roper Washer
The gears in top are stripped out need replacing, take cap off agitator and take out bolt pull agitator out ..pull top part agitator off and replace gears
Here is what the gears look like for the top part of the agitator
top part of agitator
bottom
Oct 17, 2007 | Tecnik TKL9260 Front Load Washer
Washer make a clicking noise
Zoobs, you could have something stuck under the agitator. The agitator will pull straight off. Grip it on each side and pull up hard, but don't hit yourself in the face. If that don't work, try slipping a belt under it and pull. Check for something caught under it. Another possibility could be the nylon suspension rod socket supports in the back. They will make a noise during agitation if they are dry. Put a little 3 in 1 oil to quite them down. Take the front panel off and check the pulley and belt, see if anything is out of whack. I also often find the motor support hitting the bottom panel during agitation making noise. Take the front panel off and observe during agitation. See if the support is striking the bottom. If so, just bend the bottom panel down. Catriver..post back.
Nov 30, 2006 | GE WHSE5240D ENERGY STAR Super Plus 3.2...
Whirlpool Ultimate Care II GSW9650LW Top Load Washer Logo
70 people viewed this question
Marvin
Marvin
Michael Thomas
Michael Thomas
